Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 94
Thread: First Ever Build!
    Re: First Ever Build!
    Quote Originally Posted by FazFly View Post
    hey Snuts,
    Can I do away with the tiller bar and run my tail wheel off the rudder servo? I opened up the fuselage centres, hoping to make a hole in the tail floor same as the rudder push rod and make a push rod steer wheel. Or am I dreaming of something that will never work?
    Hey Joe, Dale can speak from experience, but I see no reason you can't steer your tail wheel off a "slave" push rod. Probably end up being a little heavier and more complex than a tiller. On some of my planes I haven't even bothered hooking up my tiller/springs to my tail wheels...depending on the surface you fly from the ground handling is decent with the tail wheel free wheeling.
    Member habs992000's Avatar
    May 2015
    Dan H
    NCR
    Hey Joe, built this kit last winter....putting the finishing touches on it now, mainly setting COG. Maiden and wing for me this summer!
    Senior Member -Snuts-'s Avatar
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Quote Originally Posted by Cosmith View Post
    Cory, I wind my own tail wheel spring and leg. Silver solder the tiller to it. A real custom set-up. After 30 years of tail wheel problems I started building my own assemblies (10 yrs ago). Such that I suspend many tail draggers from the tail wheel coil spring in storage, and transport. Wind the LT-40 one out of 3/32 music wire. Wish I could provide a phot, or how-to but that is three provinces west of me now.
    -Snuts-
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Quote Originally Posted by habs992000 View Post
    Great choice. You will simply love the way it flies. Better yet, the pride of built-by-me added.
    -Snuts-
    Member FazFly's Avatar
    Aug 2015
    Joe F
    Spektrum DX8
    Ok guys, update time! I took your advice and cut a plywood double for all 3 sections of the floor to add some strength for my new gear setup, here's what they look like.
ID:	7712   Click image for larger version.
ID:	7713   Click image for larger version.
    Aug 2015
    Joe F
    Spektrum DX8
    All glued and ready for prep stage!
    Senior Member cgeisel11's Avatar
    Colin G.
    Received: 61
    Given: 38
    Looks great, Joe! Nice work. What are you planning on powering it with?
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Nice smile. I sense the pride. Most ARF's run short on that aspect of the hobby.
    Post -Lots-, most of us like to follow a build.
    -Snuts-
    Aug 2015
    Joe F
    Spektrum DX8
    Quote Originally Posted by cgeisel11 View Post
    I know everyone will be disappointing but its going to be electric, this is the power plant I'm using. http://www.hobbyking.com/hobbyking/s..._46_Glow_.html Should be plenty of power for a beginner plane.
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Many may not expect "me" to promote electric. But yes, a very good option, when reliable, duplicatable power is an asset. No reason to add dead stick landings to the lesson.
    -Snuts-
