Ya Gary... totally sold on the HV Revolectrix.
I got the blend 427 (4.27V/cell) and they are whicked. Also lighter than the standard Blend420
| Received: 9 Given: 5 |
How "Giant" do you wanna get?
Anybody have experience with one of these? http://www.dualsky.com/motor/GA_Series.shtml
Still trying to figure out which way I want to go with my 2M Vertigo...seems the motor of choice is the Hacker A60-18L. It may be petty but I hate the fact that it requires a mount that supports it front and rear. The Dualsky motor is a bit heavier but I'll probably save some by being able to mount it on standoffs. I also understand that these electric setups on this plane can be a bit tail heavy, so a bit of extra weight in the motor might not be a bad thing.
Any opinions?
The HV Revo's work awesome and can be used anywhere so I'm told. The Blend 427 is 4.27V / cell, so on 12S you can get an extra 0.8V. The blend 435 is 4.35V/cell, so an extra 1.8V. It really feels like turbo boost!!!
Another question for anyone that's had a Hacker A60....does it come with a sleeve so that it will work with a 10mm prop bore?? Seems to be the popular prop bore on the big props but the motor has an 8mm shaft.
Cory... At Thunderbolt RC, Jeff sells a shim Kit by Falcon that fits in the 10mm bore of the prop and is a perfect fit over the A60 shaft.
http://www.thunderboltrc.com/index.p...oducts_id=1890
I use them on both of my A60's and they work mint.
