Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: WOLF in SHEEPS CLOTHING
    Senior Member BAMDFISHER's Avatar
    Brian Fisher
    North of Parry Sound on Georgian Bay
    Spektrum DX18 Voice Options
    Received: 13
    Re: WOLF in SHEEPS CLOTHING
    STAB & ELEVATOR ASSEMBLY
    The Stab on this airplane is glued in. You must remove the Elevators to get it into the slot in the fuselage. The flat barbed hinges hold very well in spite of not being glued in, so don't forget to glue both elevator sides!
    I was not happy with the loose fit of the Stab into the fuselage, so I added a small balsa triangular stock to give added strength to this area. It nice that Pilot sends you a small piece of spare covering in each colour.
    As this plane will be flown off of water, all of the servos that are exposed to any spray or mist are going to be WATERPROOF SERVOS. For the Elevator, I used Hitec 5646WP. they have 156 inch ounces of torque, more than enough. The building specs call for a minimum of 118 inch ounces.
    As the servo leads travel though small openings inside the fuselage, I protected the wires with a braided wire loom. The servo lead and extension attachment was also covered with shrink tubing for extra strength, water resistance and so they could not ever vibrate loose.
    These particular servos are a bit long to fit into the precut opening. I had to lengthen the slot for the servo by about 3mm.
    After I had fitted the servo, I coated the edge of the opening with a clear glue to make this area completely waterproof.
ID:	3370   Click image for larger version.
Name:	TRIANGLE STIFFNER.JPG
ID:	3371   Click image for larger version.
Name:	WIRE EXTENSION SUPPORTS.JPG
ID:	3372   Click image for larger version.
Name:	WATERPROOF SERVO.JPG
ID:	3373   Click image for larger version.
Name:	SERVO LEADS.JPG
Name:	SERVO OPENING.JPG
ID:	3375   Click image for larger version.
ID:	3376   Click image for larger version.
Name:	ELEVATOR SERVO.JPG
ID:	3377   Click image for larger version.
Name:	STAB ELEVATOR.JPG
    Brian Fisher
    Received: 13
    RUDDER INSTALLATION
    As I am using a large engine in this airplane (EME 55 with Auto Start), I elected to mount the rudder servo at the tail to compensate for the projected nose heavy situation I might have.
    Pilot have made a cut out for the servo in the back of the fuselage just for this situation. They do though, supply all of the necessary hardware for a typical Pull - Pull condition with the servo cut out in the middle of the inside of the fuselage.
    I used my own hardware for this set up. Pilot does NOT supply the hardware for this installation situation.
    Again I used a WATERPROOF SERVO, the same kind as used for the Elevators. Threading the servo extension lead through the fuselage was the hardest job in this assembly. I also sealed the servo to the fuselage with clear "GLUE" to stop any moisture from entering the back of the airplane.
Name:	RUDDER ASSEMBLY.jpg
ID:	3380   Click image for larger version.
Name:	RUDDER SERVO.jpg
    Senior Member Bhughes's Avatar
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 392
    Given: 360
    Good I see there's a spot for a servo in the tail for the rudder. I've been looking at this too
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 392
    Given: 360
    Are the ailerons and flaps setup to work together like the decathlon. Or the flaps can only act as flaps
    Brian Fisher
    Received: 13
    Quote Originally Posted by Bhughes View Post
    The flaps can be programmed to act as Flaps in the Normal tradition, coupled to act as Aerilons or to work in the Crow position. Each Flap and Aerilon has its own servo, so they can be programmed what ever way your transmitter allows. I'm using a Spektrum DX18.
    Brian Fisher
    Received: 13
    RECEIVER
    I'm using a Gyro in this application because there is ALWAYS a breeze on my dock. Every afternoon and evening in the summer, I can count on a 5 to 15 mph wind. It's great for living as we never need air conditioning here (always 23C 72F in the summer) and there are no blackflies or mosquitoes.
    Mounting the Gyro horizontally, took up room that normally would be used for the Receiver. This forced me to mount the Receiver vertically just behind the wing tube.
    I made a mounting plate from a Carbon Fiber tray I got from SDS Hobbies and then attached a Industrial Strength Velcro strip. The back side of the Receiver is covered with the mating Velcro strip. As extra security I wrap around another Velcro Strap to hold everything in place.
    The three remote satellite's are mounted just back of the wing opening.
    This plane eats up Receiver Ports!
    #1 Throttle
    #2 Right Aerilon
    #3 Right Elevator
    #4 Rudder
    #5 Left Flap
    #6 Left Aerilon
    #7 Right Flap
    #8 Ignition Kill (Very Important with the plane in the water at the dock)
    #9 Left Aerilon
    #10 Choke (Again hard to do manually when the plane is in the water)
    #11 Auto Engine Start
    #12 Gyro Gain Control
Name:	MOUNTING PLATE.jpg
ID:	3397   Click image for larger version.
ID:	3404   Click image for larger version.
Name:	RECEIVER WIRING.jpg
ID:	3403   Click image for larger version.
Name:	RECEIVER LOCATION.jpg
ID:	3402   Click image for larger version.
Name:	VELCRO STRAP.jpg
Name:	BACK OF RECEIVER.jpg
ID:	3400   Click image for larger version.
Name:	PLATE WITH VELCRO.jpg
ID:	3399   Click image for larger version.
    Brian Fisher
    Received: 13
    GYRO INSTALLATION
    In this airplane I have chosen to use the PowerBox iGyro 3e.
    I used a carbon fiber plate I obtained from SDS Hobbies and mounted it on 6 hard plumbing washers that I attached to a plywood tray.
    The tray is screwed in so that if in the future I have to get to the rear float support, it won't be an impossible task.
    To attach the iGyro to the receiver I used 8" Male to Male Heavy Duty 20 gauge extensions from Thunderbolt RC.
    The wiring of the Gyro in between the Receiver and the Servos is a easy task. Teaching each servo the correct movement is quite simple once you have done it at least once.
Name:	GYRO MOUNT.jpg
ID:	3405   Click image for larger version.
Name:	GYRO RECEIVER.jpg
ID:	3406   Click image for larger version.
Name:	MALE MALE LEAD.jpg
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 392
    Given: 360
    Quote Originally Posted by BAMDFISHER View Post
    Nice full length Ailerons for some fun.
    Brian Fisher
    Received: 13
    The aerilons on this plane are huge. I'll be posting pictures of them when I have completed the wing assembly.
    Dwayne Butler
    GYRO INSTALLATION
    i think you find good setup, I am utilizing a GY48V as a part of Spitfire rudder in Heading Hold mode on takeofs time for me its works fine. I switch it off after in air. I found this double rate gyro so it has both HH mode and rate mode working.
