Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Skymaster Large F18
    Re: Skymaster Large F18
    MKS-599 servos on elevators.
    Exact same setup as the last two SM F14’s I’ve assembled so pretty familiar.
    Takes a bunch of shimming and adjusting but all good now!!
ID:	23467   Click image for larger version.
ID:	23468   Click image for larger version.
    Rudders done also. MKS-599 servos again. I replaced the stock hardware with good Dubro HD ball ends and Ti links
    If you’ve never used the Powerbox servo wire and connectors, you need to. About 1/2 the weight of normal wire and so easy to work with. Once you crimp these ends you will never go back.
    Found some clear HS tubing at Sayal.
ID:	23472   Click image for larger version.
    Twin pipes and nozzles installed...
ID:	23474   Click image for larger version.
    The pipes don’t have much of a bell-mouth on them and the rudder servos are fairly close to the turbine nozzles so fab’d up some heat baffles. Feeling good about everything back there
ID:	23476   Click image for larger version.
ID:	23477   Click image for larger version.
ID:	23478   Click image for larger version.
ID:	23479   Click image for larger version.
    Tomorrow I’ll work on installing the twin Cheetah 160’s!!!
    Hanes E
    Received: 32
    Given: 42
    What diameter of HS tubing did you grab. It is sweet looking
    Quote Originally Posted by Old School View Post
    3/8”
    Jan 2020
    Steven P
    Waterloo
    JR
    Hey,
    Where do you source the power box wire and connectors? What crimper is required? I make all my own extensions after having some issues with cheap ones.
    Steven
    Jan 2020
    Steven P
    Waterloo
    JR
    Hey,
    Steven
