Page 2031 of 2049 FirstFirst ... 10311531193119812021202920302031203220332041 ... LastLast
Results 20,301 to 20,310 of 20489
Thread: The official Riff-Raff thread (never ending engine thread, East/West)
  1. #20301
    wingburner
    Re: The official Riff-Raff thread (never ending engine thread, East/West)
    Quote Originally Posted by Bhughes View Post
    Oh yes I do.
    Double pane sunglass shiny!!
  2. #20302
    Senior Member Satellite's Avatar
    Ray O'Hara
    Stettler, Alberta Canada
    Received: 15
    Given: 10
    Brodie ---- you have not told us yet what that new shinny motor is going in ??? Please do not just put it on the top shelf to look at , it needs to be in the air !!!
  3. #20303
    Senior Member Bhughes's Avatar
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 392
    Given: 360
    Quote Originally Posted by Satellite View Post
    It was on the floor of my garage. Now if upgraded to the work bench. Going in my 104” slick probably. Unless I upgrade airframes
  4. #20304
    Junior Member VA6WGO's Avatar
    Will Gross
    Red Deer
    Futaba 18MZ
    Quote Originally Posted by Buck Tracker View Post
    Huh thats a bummer, seems QC is lacking across the board. I almost feel like calling AJ and letting him know where they can improve, not to complain lol I'll leave that here but I just wonder if he is aware or if he's tried to make changes but the factory won't do anything?!!?
    My laser has the following issues;
    Cowl and/or motor mount template way off
    Surfaces hinged very poorly. BTW, taping them at full deflection after scalping out a crap load of glue has relaxed them for almost a smooth feel, still not perfect
    Hardware- all garbage, ball links are oxidized and crazy stiff, thrown away, the 4-40 bolts and nuts are clearly a bad chinese knock off, hold them side by side with Dubro and the threads look funky, won't trust those on a 35%er(no they are not metric). the landing gear bolts were SAE and the nuts supplied were metric, weird. Had my own nuts to use hehe i said nuts
    Blind nuts in one wing are rough as hell, gotta find a 6mm tap to clean them up and new bolts since the 2 in that wing are fooked. or I'll replace them
    Other than all that it's great.... graphics are all on now!
    Hi Dean,
    I hope you like it as much I like mine, it tracks nicely and it flies great, rolls awesome and snaps like there is no tomorrow! I had very similar hardware issues but thankfully everything lined up properly in mine.
    Cheers,
    Will
  5. #20305
    Senior Member Buck Tracker's Avatar
    Dean
    Ponoka
    Received: 63
    Given: 154
    Quote Originally Posted by VA6WGO View Post
    Hi Dean,
    Cheers,
    Will
    Thats good to hear Will, you can fly mine and help me set it up!! Well I've put alot of time into the control surfaces, there is just one ail that is giving me greif, right at about 35 degrees is start to stiffen up...When I set up the dual servos I'll watch the amps to see if it affects that or not.
    Just got the last of parts today so on the home stretch and then just waiting for spring to happen I guess.
    I am looking forward to getting her up
  6. #20306
    Dean
    Ponoka
    Received: 63
    Given: 154
    Trevor and any other Power Box junkies, I have a thread in the electronics area for the Mercury SRS but I hope we can all use it for any questions, learning, sharing holding hands whatever....I've just gotten mine today from Thunderbolt so diving in!
  7. #20307
    Will Gross
    Red Deer
    Futaba 18MZ
    Hi Dean,
    Not sure if this helps but I am using the middle hole on the control horn closest to the wing root (servo 1) and the the top hole on servo 2 (control horn closest to the wing tip). It has the best geometry throughout the entire travel.
    Cheers,
    Will
  8. #20308
    Dean
    Ponoka
    Received: 63
    Given: 154
    Hi Dean,
    Cheers,
    Will
    That helps a lot, I was wondering about that, thank you. Couldn't find mention of itin the manual or forum, the EF planes have different sized control horns andd that I guess accomplish this same effect.
    What did you end up for throws on your ail?
  9. #20309
    Will Gross
    Red Deer
    Futaba 18MZ
    Hi Dean,
    On full deflection for 3D I am around 47 degrees. As you know it has huge ailerons
    I am using around 38 degrees for snaps.
    3-5% aileron differential.
    For knife edge 2% rudder to ailerons (left rudder) and about 1% the other way.
    4% down throttle to down elevator (for down lines)
    Cheers,
    Will
  10. #20310
    Dean
    Ponoka
    Received: 63
    Given: 154
    Hi Dean,
    Cheers,
    Will
    Thanks Will! What you running your CG at?
    Unfortunately I'll get nowhere near 47 degrees on the ailerons as my surfaces were glued too tight, hopefully 37-38 will be enough, its enough on my EF slick but every plane seems a bit different...
There are currently 16 users browsing this thread. (0 members and 16 guests)
