Page 14 of 23 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 226
Thread: Sebart Avanti S - Twin Builds :)
  1. #131
    Re: Sebart Avanti S - Twin Builds :)
    Well Joe.. I tried, but no luck. Cycled it 3 times and the imbalance is actually getting worse. Even if I did revive it now I would be nervous using it. So I will get a new one. My fault. Oh well.
    I just accidentally depleted a 2s lipo down to like 4.4v, how do you trick your charger. Mine thinks the cell count is wrong
  2. #132
    I just switch it to NiCd and hit it with 30 seconds of charge to bump the voltage up to close to nominal and then flip quick to Lipo and it should catch!!
    Perhaps there are better ways though!
  3. #133
    Rick Bruce
    Newmarket
    PowerBox Core; Futaba 14MZ; Spektrum DX18QQ
    Hey Trev, I'm here......awesome Jet
  4. #134
    Hey Rock!!! Welcome and thanks!
    Don't forget to let us know when you plan to maiden the Futura!!!
  5. #135
    All set!! Got a new 2S-2700 pack.
    Avanti is ready however the forecast is calling for high winds and scattered showers tomorrow
  6. #136
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Hey, I thought you said you didn't know anything about LiPo's!!
    You hit it right on with that one. Just remember..........don't walk away with it set on Nicad. LOL!!
  7. #137
    I don't Brent.. just a good guess, LOL
  8. #138
    Tigger
    Received: 5
    Given: 8
    You can see I've also had the Behotec220 fitted in there because the motor mounts are cut out, LOL.
    Hi,
    What kind of tool do you use to cut out so properly the wood in such a small space ?
    And about your nice nose gear reinforcement, I would be afraid of breaking the fuselage in case of hard landing, instead of the original wood plate.
    In case of "hard-anything", there is always something that breaks... such as your plastic arm on your steering servo !
    And I also do prefer to break this plastic arm than a servo, whatever price it costs !
    I expect to receive my avanti today or tomorrow, according to tracking number, and the electric gear, the VT pipe and dubro 3 liters tank later, but I don't know when !
    I'm a 6 years old boy on christmas day !!!
  9. #139
    Quote Originally Posted by tiggerletigre View Post
    Hi,
    Woohoo! Congrats on the news of getting it today! Christmas in April!!!
    Ya - definitely tough getting deep in there to open up space for the turbines!! I use one of these oscillating saws... cuts through the mounting rails like butter and the blade can be oriented 90deg to the tool, so easy working!! I then just cleaned it up with a Dremel tool and a cable extension with a disk drum on the end
    http://www.zorocanada.com/i/G4912381...KlkaAjxg8P8HAQ
    I hear you about the front gear plate. As it is now, I don't think the fuse will break (the fuse seems really nice and stiff), I think the whole front nose gear assembly would break out rather than just tearing out the mounting plate. All that being said, I hope I don't test this theory, LOL.
  10. #140
    Tigger
    Received: 5
    Given: 8
    Thanks for the link. I have never used this kind of saw.
    Seems to be quite usefull in small spaces.
    I hope you won't test fuselage flexibility either !
    Good luck for the weather for maiden !
