Page 1972 of 2049 FirstFirst ... 97214721872192219621970197119721973197419822022 ... LastLast
Results 19,711 to 19,720 of 20489
Thread: The official Riff-Raff thread (never ending engine thread, East/West)
  1. #19711
    Re: The official Riff-Raff thread (never ending engine thread, East/West)
    Quote Originally Posted by Buck Tracker View Post
    rodger that Trev thanks, I am literally amazed though, like 10 flights in a row I would lean it and I have yet to hit the too lean wall, guess just keep going.
    One thing I did that has helped and likely why it was so rich was it was running pretty hot, I had lots of air exit but the intakes on the 89 slick were too small, I've opend them up and it;s helped, going to do more again.
    What temps to find yours to run at?
    My last flights I was between 275-320 but mostly around 290 F
    I'm in that range for temps also Dean. Really depends where you have your sensors though.
    Cory had issues with blowing lots of oil from his DA70 and he sent it back to DA for a checkup a few weeks ago . Cory - has DA gotten back to you on it yet?
  2. #19712
    Senior Member bradleyban's Avatar
    Brad
    Petawawa ON.
    Futaba 8FG Super
    Received: 158
    Given: 75
    Hey on another note, been loving the crap out of my DA 70 / 89" slick combo, been leaning that motor out every flight, I've taken the low down 1/2 turn and it's really coming alive, crazy nice but my question is when the hell will it stop puking out this silly amount of oil???????? One flight is equal to a days worth of sludge or more than some of my other motors.
    what kind of oil you using? I used amsoil dominate in that past and it would puke out nasty sluggy black. switched to sabre line and went away. now running klotz and it seems to be clean too
    When in Doubt Braaaap it out!!
    Huckin' In The Valley www.huckininthevalley.com
  3. #19713
    Senior Member Always Flying's Avatar
    Mannyh
    Received: 128
    Given: 199
    Dang Jim! That really sucks - what do you do?!? Not your fault! I hear your a really good cook!.....I’d make someone else do the dishes
  4. #19714
    Senior Member Buck Tracker's Avatar
    Dean
    Ponoka
    Received: 63
    Given: 154
    sensors are in the proper spots, not first rodeo LOL back of motor bottom fin
    For shits and giggles on the ZDZ 97 I'm pissing around with, I put one on the back and one on the front(cause there are 2 sensors and figured might as well use them both) and there is about a 20-30 degree F difference throughout a flight on that motor
  5. #19715
    Dean
    Ponoka
    Received: 63
    Given: 154
    Quote Originally Posted by bradleyban View Post
    the usual, red line 40-1, is this the start of an oil war, I'm open to a switch after I burn up all what I have!!!
  6. #19716
    Brad
    Petawawa ON.
    Futaba 8FG Super
    Received: 158
    Given: 75
    not at all just reporting some findings I had. all.oil is good. even baby oil
  7. #19717
    wingburner
    Redline is way way overpriced. I'm going to go Lucas semi synthetic once my redline is gone/always available at canadian tire. The guys selling it here are raping us!!!
    $25 redline...$12 for Lucas semi synthetic....same size bottle and has been rated better that redline.....no more hype at The Hut!!!
  8. #19718
    wingburner
    Does that leave the cylinders baby a$$ smooth?
  9. #19719
    Dean
    Ponoka
    Received: 63
    Given: 154
    haha ya just razzing you but seriously I'm open to a change shortly, motor bud in town swears bybStihl Ultra, thats easy enough to get as well
  10. #19720
    There is only one oil that does anything... iPone Strawberry scented. The seeds are like lubrication boosters.
    Everything else is garbage.
    Oops... hope that doesn't start an oil war.
There are currently 16 users browsing this thread. (0 members and 16 guests)
