Page 39 of 51 FirstFirst ... 29373839404149 ... LastLast
Results 381 to 390 of 502
Thread: My First Scratch build
  1. #381
    Rick Bruce
    Newmarket
    PowerBox Core; Futaba 14MZ; Spektrum DX18QQ
    Re: My First Scratch build
    Wow Trevor looks totally awesome...nice work
  2. #382
    Senior Member cgeisel11's Avatar
    Colin G.
    Received: 61
    Given: 38
    Nice work Trev! Looking forward to the water test at Lake X!!!
  3. #383
    Banned
    Received: 49
    Quote Originally Posted by RickyBoy View Post
    Thanks RickyBoy!!
    Quote Originally Posted by cgeisel11 View Post
    You bettcha buddy..
  4. #384
    Banned
    Received: 49
    Bottom left stab under vacuum. Wasn't going to spend $12US AND $70 SHIPPING!!!!! for a plastic quick lock, so I made my own for $11 bucks. Nor was I going to pay $5 per meter of vacuum bag. I just purchased 20 XXL Clear garbage bags from Wallymart for $6 bucks
ID:	17748   Click image for larger version.
  5. #385
    Banned
    Received: 49
    Couple of pics.. right stab skins are done.
ID:	17834   Click image for larger version.
  6. #386
    Banned
    Received: 49
    Well things are turning out great. I'm very happy with the core build up product. It's called lancor sorric. It's not Honey comb. It just looks like it. Its seems a bit pricey.. but I have yet to compare the price to balsa. It is better than balsa in the way that it conforms to any curve whereas balsa can only go one way or the other.
    Just an FYI for those of you using an oil vacuum pump.. the light smoke that comes from the pumps vent may seem docile, but in time will fill your garage with an oily mist and eventually coat everything in the shop with a thin layer of oil. Not good to breath in. Its best to connect a hose to the vent and run it outside.
ID:	17916   Click image for larger version.
  7. #387
    Senior Member JBajkor's Avatar
    Joe Bajkor
    Hamilton, Ont
    Received: 5
    Good tip for the vacuum pump. Thanks
  8. #388
    Banned
    Received: 49
    No problem Joe I found a 20-foot length 3/4" at Home Depot(plumbing) for 12bucks, fits in the pump perfectly
  9. #389
    Banned
    Received: 49
    I'm getting pretty good at the bagging with regards to a perfect seal.. though I still have to constantly check it and give it a pump once or twice. It's kinda nerve racking, so I decided to use a switch. I didn't want to go with the expensive electronic switches that you can only get from the US and pay a fortune in shipping + duties, taxes and waiting for a week or more...so I made my own for $5. That was the cost of the 15a 125v switch.
    The syringe has a spring inside. When vacuum is at 8 bar the spring is compressed releasing the switch and turning off the pump. When/if it loses vac (5 bar)the spring pushes the plunger out which activates the switch starting the cycle again.
ID:	17984   Click image for larger version.
  10. #390
    Banned
    Received: 49
    Bottom right stab. This is a live hing
There are currently 4 users browsing this thread. (0 members and 4 guests)
