Page 22 of 53 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 524
Thread: Aviation Design Diamond / Behotec 220
  1. #211
    Re: Aviation Design Diamond / Behotec 220
    Congrats Peter!!
    Yep... huge speed envelop. Insane top end speed and walking speed landings!!
  2. #212
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Great news Peter!!
    Congrats on the maiden.
  3. #213
    Senior Member RC_MAN's Avatar
    Aug 2015
    PJD
    Ontario
    Futaba 18 MZ, Powerbox Core,
    Thanks. I was flying formation with Ricks Futura. He was maxed out at 187 mph and I was at 30% power. Crazy fast jet.
  4. #214
    Aug 2015
    PJD
    Ontario
    Brandon I used hysol epoxy to fasten the light to the tip tanks.
  5. #215
    Banned
    Trevor M
    Beeton Ont
    JR12x
    Given: 32
    Quote Originally Posted by RC_MAN View Post
    At first I thought you were kidding lol... but then I thought "no, thats about right " Congrats Pete!
  6. #216
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Hey RCman did you say you have the light kit made by oli? I got my light with loom and for some reason I cannot seem to get any of the landing lights in the L1 and L2 outputs. They go into the 120 mA landing lights in L1 with the jumper removed for the lower power setting and then the front retract landing light, which is a higher power in L2. I put it on a 3 position switch, and the off and flying position work but the landing lights do not come on in position 3... the radio is set to 100% ppm throws...
  7. #217
    Aug 2015
    PJD
    Ontario
    Hi make sure the jumper plug is plugged in as per the schematic.
  8. #218
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Was trying to confirm correct wiring on the controller... Oli got back to me so now i just have to check the wingtip landing led's to see if they are burnt up...
  9. #219
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Well I had been recommended to use the MKS 777 Servo in the diamond (the mks 777 is slightly taller than standard which requires modification) but I talked to somebody who freaked out because they said if you have to cut away some of the frame inside the control surface you will weaken a side and could induce flutter so now I have to repair the frames on my two elevator servos and rudder. That sucks has anyone else use the 777 servos or have any recommendations please. Thanks
    In hindsight, maybe I didn't have to Mount the servo all the way against the servo mounting cover but instead I could have mounted it with a gap which may have cleared the frame...
  10. #220
    Brandon.. I only use Futaba BLS172's in my airplanes. Insane servos (stronger and faster than the specs + an incredible drivetrain + soft start + normal size +,+, +).
    These Diamonds take an incredible punishment and is one plane I would not want to take any chances on in terms of structural strength or servo power. While the MKS777 are strong and good servos, the idea of having to modify anything and potentially weaken something scares me.
    Also... make sure you get the metal servo cover upgrade. If not you get cheap white plastic servo covers/plastic mounts which scares me so much considering this thing moves at 450+ kph and pulls huge G's.
