Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Engine Test Stand Plans
    Member GMuglia55's Avatar
    Gabriel Muglia
    Ottawa Ontario
    Given: 34
    Does anyone have some plans for an engine test stand? Mostly for 30cc - 200cc engines. Thanks in advance!
    Sponsors:
    Pro-RC Canada -- http://www.pro-rc.ca/
    AeroPlus RC -- http://www.aeroplusrc.com/
    Re: Engine Test Stand Plans
    If you can wait for a week or so, I'll do up some plans for the one we've been using for 6+ years around here.
    Gabriel Muglia
    Ottawa Ontario
    Given: 34
    Thanks a lot Trevor!!
    Senior Member Dennis 9412's Avatar
    Dennis DuBois
    Washago, Ontario
    Airtronics, JR
    Received: 17
    Hey Trev:
    I would like a set myself if you wouldn't mind.
    Regards,
    Dennis
    Dennis DuBois
    MAAC 9412L IMAC 3821
    CFI Orillia Aeromodelers
    AZD Zone L
    Sure! I'll pdf it and will post it here along with some pics!!
    At some point when things slow down for me i'm gonna make of a V2 with thrust measurement and the motors will be mounted upside down so exhaust is on top for easier headerlength adjustment!!
    Dennis DuBois
    Washago, Ontario
    Airtronics, JR
    Received: 17
    Thank you sir, you are a gentleman and a scholar!!
    Regards,
    Dennis
    Test Stand Dimensions
    As promised, now that I'm done the engine testing for a while, here are a few pictures of the test stand we've been using for the past 6 years. When I build a Version2, I'll post a quick build thread!!
    The stand is really only 5 pieces of 3/4" Spruce Plywood with a whole bunch of different motor plates.
    Base Plate
    Width at front = 27"
    Width at rear = 13"
    Depth = 25"
    (2) Sides
    Height = 35"
    Depth at base = 24"
    Depth at top = 7"
    Front Plate
    Height = 35"
    Width at base = 27"
    Width at top = 13"
    Retangular cutout = 8" wide x 20" tall, starts 5" above baseplate
    Carb cutout = 5" x 5", starts just above equipment tray which is 9.5" below top of stand
    Bolt standoff spacing = 7" wide x 5" tall
    Equipment Tray
    Width = 11.5"
    Depth = 17"
    Features = holds gas and glow tank, Rx, battery, switches, tach, throttle servo
    Motor plates
    Height = 9"
    Width = 10"
    Features = Each one fits different motors. We started with a bunch of blanks and we modified as the different motors needed testing.
ID:	2067   Click image for larger version.
ID:	2068   Click image for larger version.
ID:	2069   Click image for larger version.
ID:	2070   Click image for larger version.
    Gabriel Muglia
    Ottawa Ontario
    Given: 34
    Base Plate
    Width at rear = 13"
    Depth = 25"
    (2) Sides
    Height = 35"
    Depth at base = 24"
    Depth at top = 7"
    Front Plate
    Height = 35"
    Width at base = 27"
    Width at top = 13"
    Equipment Tray
    Width = 11.5"
    Depth = 17"
    Motor plates
    Height = 9"
    Width = 10"
    Thank you very much Trev!
    Senior Member lorne@pro-rc.ca's Avatar
    Lorne
    Trout Farm Flyers
    Received: 67
    Given: 31
    You can see one of these stands at my shop gabe. work very well
    Proud Member of the Trout Farm Flyers
    Pro-RC Fly The Hype!!!
    Senior Member Always Flying's Avatar
    Mannyh
    Received: 128
    Given: 199
    Built one of these stands! they are timeless..best set up EEEEEEVAH!
