Page 7 of 18 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 176
Thread: Jtec Radiowave 2.8m MX2 Build(s)
  1. #61
    Gordon Wilhelm
    JR 28x
    Re: Jtec Radiowave 2.8m MX2 Build(s)
    You don't have to be crazy to do an indepth build thread, but it doesn't hurt!!
  2. #62
    Enjoy the balsa dust during the sanding Alan. Very therapeutic
    At least some of us are normal. Gordon on the other hand...
  3. #63
    Gordon Wilhelm
    JR 28x
    If you've seen my picture on the cover of this month's MAAC magazine you know that I'm not normal! LOL
  4. #64
    Ha!! I actually just sat down to read the magazine about 30sec ago and I recognized the MX2!! Congrats
    I don't see any glue down for that stringer, LOL.
    Congrats again
  5. #65
    Gordon Wilhelm
    JR 28x
    Thanks, pretty much a staged photo of "dry fitting" the stringers. My wife saw the magazine first while I was out working and told me that I looked like someone pee'd in my Wheaties! Lol
  6. #66
    Member Scrappy's Avatar
    Jan 2016
    Alan H
    Calgary
    Hitec
    Received: 18
    Funny how your mind works, went into the shop last night to get working on the wing cores and somehow the Turtledeck core got sheeted up!!
    I had been looking at the foam T-deck core and was figuring out a plan to attack it a couple of days ago and had cut a few pieces of 3/4" MDO sign plywood I had to use as a clamping system, I left the foam and cut plywood on the bench so when I went into the shop it was natural to just start to it!
    So... I cut 2 angled pieces of the plywood to clamp in the sides and one piece to set the weights on. I used cut 90 degree pieces of plywood to hold one piece in place and screwed it down to a wooden base(first picture) and then clamped everything up square and tight and screwed several angle braces into place along the front edge to use for when I "loaded" the foam up with the windexed sheeting to form it (second and fourth picture). I was able to better control pressure from my clamps this as it used a squeezing pressure from the bottom up. I was able to just use 2 clamps this way and it gave me good access to check the top edges.
    To get edge pressure where the sheeting leaves the foam press and tries to splay outwards I had some 3/4 x 1" aluminum angle that slipped in along the edges (plywood sides were cut taller for this reason) and to apply pressure I just used screws, the deeper into the foam (third picture) they went the more wedging effect took place so I could tune it as I wanted to.
    Fifth picture shows it all loaded up with the glue and weighted down (hey, use what you have handy!!) and the last picture shows the final result which I am super stoked about as it is darn near perfect!!!!!
    At least to my eyes!
    So...tonight and tomorrow night I have to get the cores prepped with the root rib, falase rib, and the phenolics glued in so I am ready to take them up to Gordon's this weekend to begin the sheeting!!
    (Shh...but I think he wants to do mine first as practice before he does his....just don't tell him I said so!) LOL!
ID:	9095   Click image for larger version.
Name:	Sheeting Forming.jpg
ID:	9096   Click image for larger version.
Name:	Edge Pressure.jpg
ID:	9097   Click image for larger version.
ID:	9098   Click image for larger version.
Name:	All Weighted Up.jpg
Name:	Finished Result.jpg
    Yep, I meant to do that.....
  7. #67
    Gordon Wilhelm
    JR 28x
    Nice way to deal with the t-deck sheeting! We can do my wings first if you want LoL
  8. #68
    Jan 2016
    Alan H
    Calgary
    Hitec
    Received: 18
    Quote Originally Posted by Trumpetman View Post
    Thanks! And I am good with your or my wings first...
  9. #69
    Jan 2016
    Alan H
    Calgary
    Hitec
    Received: 18
    I just thought you looked very, very serious....
    Who knew a stringer could cause that much concern!! LOL!
  10. #70
    Gordon Wilhelm
    JR 28x
    I take the precise placement of every stringer very seriously.... NOT
