Page 4 of 18 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 176
Thread: Jtec Radiowave 2.8m MX2 Build(s)
  1. #31
    Member Phil202's Avatar
    Phil Dessureault
    Re: Jtec Radiowave 2.8m MX2 Build(s)
    Trevor,
    Jason Shulman flew the 3.1m version at the last TAS...
    One awesome looking aircraft!!
ID:	8516   Click image for larger version.
ID:	8517   Click image for larger version.
  2. #32
    Thanks Al. Sure is a sweet looking plane! And some nice scale schemes available
    Phil.. great pictures! Thanks.
    Alan.. great idea about the water as weight. I avoided buying a weight set in fear of tripping, so you confirmed my hunch, LOL.
  3. #33
    Feb 2016
    Al Young
    Futaba Team Member
    Received: 3
    Given: 23
    Quote Originally Posted by Phil202 View Post
    Trevor,
    Kevin came up with that Scheme and it currently is sitting on Kevin's dinning room table. Its powered by a DA 200 with our QC120 canisters. Jason had about two flights on it before he and Kevin went to the Shootout.
    We actually had to get it covered this time by a pro. I just didn't have the time to finish covering it. I never have had anyone else cover any of our planes so we sent it down to Florida to the person that does Jason's pattern planes. Carlos Silva, his company is Tuny Pro. He did a fantastic job. We actually sent the equipment down with the plane so Jason and Carlos installed everything so it would be finished in time for the shootout. Jason first flight was at dusk. I think he got two flights and it went in the van. Jason drove from Miami to Charlotte NC to meet Kevin. Jason got a couple hours slept and then they put the plane in our trailer and Kevin and Jason left for Tucson. Tucson is 2000 mile from us and Miami is about 1000. So Jason did about 3000 miles in a little over 3 days. I am surprised he could fly at all!! LOL
    All I can say is how proud I am of Kevin and Jason and what they got accomplished
    Sorry to be long winded
    Al
  4. #34
    Member Scrappy's Avatar
    Jan 2016
    Alan H
    Calgary
    Hitec
    Received: 18
    Thanks for piping in Al!! Always good to share some history on a plane!
    Trevor, speaking of scale schemes my avatar is a hint..... I am using that plane as a base and modding a few things up to save some time (over 400 small squares on the leading edges on that scheme as is...!!) as well as making it more visible. The underside of that plane's wing is all green & dark blue squares, I will be doing broad chordwise stripes to contrast the upper spanwise stripe effect.
    I got the LE & TE of the rudder/v-stab planed and rough sanded tonight, super cool to plane that much material off the 1/2" x 3" balsa stock!! Great long balsa curls... and just for kicks I put a lighter to one curl and WOW does that stuff burn quickly! Almost like flash paper....
    I used masking tape to hold the pieces down against a stop and it worked quite well to hold things steady. I put my guide lines inside of where I needed to plane & sand to so they would always be visible. I spent some time playing around with some ideas for the tailgear plate and how to finish up that area and will post those pics once it all comes together.....in case I have to redo anything! There is some room for creativity on some areas of this plane and this is one of them.
    I also rough cut the cannister mounting plates tonight but will need to wait for the headers to arrive before I go any further on them. DA100 on cans to start with and possibly (likely ) tuned pipes later on.
Name:	Planing the TE and LE.jpg
ID:	8528   Click image for larger version.
Name:	LE and TE Rudder.jpg
    Yep, I meant to do that.....
  5. #35
    Senior Member Machzx's Avatar
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    very nice Plane !!
    Trevor ZDZ 180 and a crazy scheme next winter build cutty cutty Pipes !! full house sbus
  6. #36
    Thanks Al... that's a whicked story. Pure passion there to pull that all off.
    Ya Ed. Has me seriously considering!! The 3.1m with a ZDZ180 or a 2.8m with piped GP123.... both sweet sounding options!!
    Here are a few of my favorite scale schemes!! Those checkers on the front are a must Alan
ID:	8539   Click image for larger version.
ID:	8540   Click image for larger version.
ID:	8541   Click image for larger version.
  7. #37
    Jan 2016
    Alan H
    Calgary
    Hitec
    Received: 18
    Hey Trev,
    Ha!! I have trouble getting long straight lines matched up, let alone 400 + squares!!
    I think I will do white on the LE on the wings for visibility, especially when it is coming towards you as I find white the most visible and will maybe add in a blue and/or green stripe... or two...
    Might also have something cool for the rudder to make it a one of a kind....
  8. #38
    Sweet!!!!
  9. #39
    Feb 2016
    Al Young
    Futaba Team Member
    Received: 3
    Given: 23
    tbrum,
    The zdz 180 would be a nice combo for the 3.1, on the 2.8 with a GP123 the one thing it won't need is pipes!!!! It will be a rocket with it on std exhaust or canisters.
    Oh and anyone of those schemes would LOOK GREAT!!
    Al
  10. #40
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    A dual build perhaps ??
