Received: 214 Given: 74 |
building 5 Cliks, objective 113 grams or better for every one. All rtf including bats ( need to supply bats so I can maintain the final weights). Airframe without bat 100 gram
Green = Ed and Scott
Red = John
Purple = Bob
and the last is Paul, I am not sure of his colour because he has the kit already.
Power will be via 3100kv motors turning 6030 props, 6a esc
Servos 4.2 gram and 2.5 gram
Kits RC Factory ( twisted hobbies) Clik ng
5 simultaneous builds occupies allot of space so that's the limit for this build.
Time to hurry up and watch the mailbox/fedex
Received: 392 Given: 360 |
Great I want to watch this. That brand flys great. The twisted hobbies crack lasers you guys were flying were sweet
Started this am, after sorting things out, readjusting the servo quantities and so on I found I need a couple more servos for spares and somehow I never ordered bats for myself or spares for anyone else -DOHH
pic 1 sorted
pic 2 cf and bagged parts sanded, mods to bag contents include small z bend wires and shrink tubing to be used at the servo end of the rods.
pic 3 just shows how to keep the lg together while glue job in progress
pic 4 shows all cf pieces cut to length, the gear all made, all cf strips sanded and sorted as well as the push rod partial assembly, must pushrods be installed to finish.
Stuffed the flat cf into the stabs and ailerons. Would have never thought it be that much work but it's done.
Just waiting a day for the kicker to evaporate and the swelling to go down ( kicker swells the epp)
Also glued the canopies to the top vertical fuse halves.
maybe more tomorrow??
Received: 307 Given: 439 |
Looks like quite the setup there Steve!!
Rock on man!
I will drop Johns and my Rx in the mail tmrw.
It may not be possible to do more today as it is my anniversary. Was thinking sex but don't know any good or even bad hookers in this town JUST KIDDING
Glued the tail to the horizontal fuse this am, here they be.
Please excuse the pics, I am having some cam issues, my s3 is what I use in the shop but it wont store pics for some reason and my note 4 is a little, make that allot smashed.
Snuck in a little more glue time.
So far I have uses thin ca and kicker for everything CF related and Foam to Foam for everything foam to foam. when I finish this sequence of horizontal foam to foam I will switch to welders glue for all things vertical. Then I will report on any difference in the two products FOR THOSE THAT KEEP ASKING STAY TUNED.
At the point now where I have all five ready for the installation of the lower vertical portion, need to let the kicker evaporate again. By doing this you allow the size of the parts to return to the correct dimension. Next will be to get the lower portion and stick farm growing, fun, fun, fun.
Pic showing two of the units with all cf installed as well as the elevator servo.
If you want to see the actual build instructions here is the manual
http://www.rc-factory.eu/tmp/soubory...LITE_green.pdf
Received: 166 Given: 192 |
Looking good!... Keep the hardwood flooring glued to mine, I'll need the extra support.
