| Received: 13 Given: 3 |
When there is not enough room in a plane for a separate smoke system, is their something that can be added to the gas / oil mixture for a 2 stroke that will produce a "Reasonable" smoke trail.
I would be willing to give up a little power for this effect? Would the addition of mineral oil help?
Brian... what about an electric smoke system???
I was thinking of trying one of these on a plane!!
http://www.smoke-el.de/lang1/movie.html
For the plane I want to use it in I think the electric system might be too complicated.
What happens if you add two stroke oil at a higher ratio?
| Received: 528 Given: 511 |
you will end up loading engine up with oil likely oil fouling the plug
after a time excess carbon causing sticky rings and carbon on the piston which can cause detonation in severe cases piston failure from it
Agreed.. motors aren't meant to smoke.
| Received: 392 Given: 360 |
Their not meant to smell like strawberrys either. Brian we could always strap the coloured smoke bombs on gets expensive though I would imagine
| Received: 2 Given: 3 |
I saw a really good smoke system in an electric powered plane....heavy thick smoke!....something to do with too many amps or something like that......
| Received: 119 Given: 6 |
Confucius says: Going to McDonald's for a salad is like going to a Hooker for a hug...:smug
