Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Pegase Composites Akuma
    Peter W and I got a pair of these Pegase Composites Akuma planes.
    I am building mine first and then will likely build Peter’s once I figure all of this out and test fly mine!
    We got these through Chad Northeast. Chad has a really cool build series on YouTube that I am using. They are a ton of work and aren’t really much different than building a Carden.
    Excited about getting back to wood and Monokote!!
    Here is Chad’s video series for the build
ID:	25687   Click image for larger version.
    Re: Pegase Composites Akuma
    Here are a few pictures of the fuse build. Chad goes into all the detail on his build videos so I won’t bore anyone repeating it.
    A summary…
    1) aft bulkhead install in fuse shell
    2) stab tube phenolic install
    3) stab anti rotation pin
    4) wing tube phenolic install
    Tons of work here. Probably have a good 10-15hr of build time into these details. Tons of alignment, measuring, laser level work.
ID:	25689   Click image for larger version.
ID:	25690   Click image for larger version.
ID:	25691   Click image for larger version.
ID:	25692   Click image for larger version.
    Got the rear rudder post fab’d, glued in with Hysol and bevelled. I also lightened it to save about 12grams
ID:	25694   Click image for larger version.
    Cool project
    I got the fuse painted! Automotive base / clear! Turned out really well. I did 1 coat of clear to keep it as light as possible!
ID:	25696   Click image for larger version.
ID:	25697   Click image for larger version.
ID:	25698   Click image for larger version.
ID:	25699   Click image for larger version.
    So the Akuma kit comes with CF landing gear but I decided to order the new Falcon CF gear and Falcon CF wheel pants from F3AUnlimited. Axles and wheels are from Morris Hobbies
    The bulkhead for the gear assembled well and only required minor shaping. All glued in with Hysol of course
    Equipment Links
    Landing Gear – Falcon + wheel pants CGL-101
    https://www.f3aunlimited.com/landing...s-black-falcon
    Axles – steel spring loaded – Japan
    https://morris-hobby.securesite.jp/51_442.html
    Main wheels for the spring loaded axles – cannot use Dubro etc. these are sold individually so you need 2
    https://morris-hobby.securesite.jp/20_439.html
ID:	25701   Click image for larger version.
ID:	25702   Click image for larger version.
    Tailwheel frame installed..
    Equipment Links
    Tailwheel Frame – Nishioka – does not include the wheel
    https://morris-hobby.securesite.jp/31_185.html
    Tailwheel
    https://morris-hobby.securesite.jp/22_67.html
    Received: 114
    So Move to the WC and get corrupted? Switch from Huckin to Pattern?
    Sad times indeed!
    Senior Member itizme's Avatar
    Steve W
    Angus
    Futaba MZ, Futaba SZ
    Received: 214
    Like when Jim went from Huckin to IMAC, so sad
    lol
    LOL. When did you fly last Jim???
    Darn Covid
