Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 65
Thread: BRAIN FART thread
  1. #51
    Senior Member -Snuts-'s Avatar
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Re: BRAIN FART thread
    Quote Originally Posted by OldPrairieRedNeck View Post
    Ok, I have been holding out on this one. Probably my dumbest brain fart EVER! Fession time!
    Not likely many of you remember the days when you used a hand crank to start a vehicle... well I still have one of those that I use to saw fire wood. #1 rule: it MUST be out of gear BEFORE starting is tried!
    I bet you didn't think I was still that quick on my feet eh?
    Well it starts easy.
    -Snuts-
  2. #52
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    I remember how happy you were when Sandra drove that one home, new.
    -Snuts-
  3. #53
    Senior Member OldPrairieRedNeck's Avatar
    Mervin Burkinshaw
    Coronation Alberta
    Hitec
    Received: 47
    It's totally amazing how quick a 5 foot gap closes up even in first gear when you are between the two!
    Had one of those but it broke!
  4. #54
    Senior Member Bhughes's Avatar
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 392
    Given: 360
    Wow merv scary. Remind not to help you on the farm lol. My grandfather got me with the hand crank and here hold this gag when I was a boy lol
  5. #55
    Member Rellic's Avatar
    Brian Tomlinson
    Vernon BC
    Received: 3
    Pull My Finger.
    Brian T.
  6. #56
    Max
    Quote Originally Posted by Rellic View Post
    Pull My Finger.
    Brian T.
  7. #57
    Mervin Burkinshaw
    Coronation Alberta
    Hitec
    Received: 47
    There are not one but TWO brain farts in this picture committed by our beloved military about 2 weeks ago.
    #1 Caught the country side on fire cooking lunch when the area under a fire ban due to the extreme dry conditions out here this spring. And yes they did promise to pay for the damage to two neighboring farms!
    #2 Take a look at where they set up the antenna for their communications base! DIRECTLY under a high tension power line! Yes the line follows the fence and the antenna is about - what maybe 6 feet away and extends 30 or 40 feet ABOVE the power line! It was also a very windy day!
    Believe it or not, no one was killed!!
  8. #58
    Senior Member Buck Tracker's Avatar
    Dean
    Ponoka
    Received: 63
    Given: 154
    I glued my left thumb and index finger together with CA about a week ago. About an area the size of a dime, took me 30 minutes with debonder and a flat screw drive to get them apart!
    I did get the part glued in the plane where I wanted it but there was a few tense moments there when I realized I had all that excess glue on my fingers!
  9. #59
    Member PaulD's Avatar
    Paul Dries
    Coquitlam, B.C.
    Futaba 18MZ
    Received: 4
    Just thought this would be an amusing idea, a sort of place to confess our "dumb - dumb" moments and have a good laugh at ourselves! In the shop, on the field or where ever.
    I will start it off with the one I just did today. See anything wrong here?
    Just put a tail wheel on the tip of the rudder. 😜
    PaulD
  10. #60
    Mervin Burkinshaw
    Coronation Alberta
    Hitec
    Received: 47
    Don't you just hate it when you have the covering all laid out nice, put the iron to it and it sticks... to the iron!!
    Yup, just did it again!
