Received: 987 Given: 745 |
Really tight inside this little beast so following some of the instructions for equipment install.
Pump and valves mounted to a plate down in the equipment area
ProJet ECU is massive so going back there also
Steering servo (9411) mounted on the middle equipment tray
I made up an upper equipment plate with an angled bridge to hold the Tams UAT
2 x Jettronics double valves - gear and doors
1 x UP1 - brakes
Jeti REX10
Powerbox Pioneer
2S-2500 LiFe for Rx
3S-2500 LiPo for turbine
ProJet telem
I installed the clear canopy with lotsa magnets and canopy glue
Once cured, I sealed the glue joint on the inside with Hysol.
Here’s the weight and CG check. Came out bang on - no lead required![]()
