Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: CPLR Hui Yang SupraSkybolt Pattern Plane / YS200
    Re: Hui Yang SupraSkybolt Pattern Plane / YS200
    Nope. Definitely not typical!
    Learning a lot about pattern ship setup!!
    Re: CPLR Hui Yang SupraSkybolt Pattern Plane / YS200
    Here is the tuned pipe install. I made the 1/16” lite ply backing plate also the ignition mount.
    Still cooling holes to cut in the lower cheek cowl to keep the YS200 cool
ID:	24952   Click image for larger version.
ID:	24953   Click image for larger version.
ID:	24954   Click image for larger version.
ID:	24955   Click image for larger version.
ID:	24957   Click image for larger version.
ID:	24958   Click image for larger version.
    Throttle servo installed with Sullivan Gold N Rod and metal clevis.
    BLS173
ID:	24961   Click image for larger version.
    Got tank plumbed up and installed. Used loop-side of Velcro around formers to cushion the tank.
    Equipment mounting plate installed and formers that secure the tank!
    I’m paranoid about a silicon line coming off, so twist wrapped all fittings with SS wire
    Battery is a LiIon 2S-2800mAh
    Switch is a Powerbox DigiSwitch, mounted from inside
ID:	24962   Click image for larger version.
ID:	24963   Click image for larger version.
ID:	24964   Click image for larger version.
ID:	24965   Click image for larger version.
ID:	24967   Click image for larger version.
    So this plane will be running Futaba SBUS. I made up a 2-piece wiring harness with Powerbox wire and servo ends.
    Nice and light this way!
ID:	24974   Click image for larger version.
    Internal wiring, iBEC, PB switch, LiIon battery....
ID:	24976   Click image for larger version.
ID:	24977   Click image for larger version.
    And final pics!!!
    CG came out perfect at 130mm behind lower wing LE
    Well under the 5kg weight limit !!!!
ID:	24979   Click image for larger version.
ID:	24980   Click image for larger version.
ID:	24981   Click image for larger version.
ID:	24982   Click image for larger version.
    Looks like we have to leave the maiden of this until the spring!!!
    In the meantime it’s ready to go back to Peter all dressed up!!!
    Senior Member thaley's Avatar
    May 2017
    terry h
    kingston
    spectrum
    love it. love the ys 200, I had a ys120 supercharged once, awsome little beast. love the exhaust on this beauty, and you were able to shoot it down to keep all that slippery slimmy glo snot off the plane, good job on this one Trevor.
    TreeD - Rainman
