Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: CompARF 2.9m MXS / GP176evo
    Got into this project tonight! Designed for DA150 so the GP176evo should be insane!!
    Crazy cool design! All servos are placed at the center of the plane (at wingtube).
    * 2 servos ganged together drives long CF pushrod to elevator bellcrank
    * 2 servos ganged together for pull pull for rudder
    * 2 servos at each wing root ganged together
    Tons of CF
    Nice canister tunnel
    Seams finished and painted
    Cool strips on LE of ailerons
ID:	24482   Click image for larger version.
ID:	24483   Click image for larger version.
ID:	24484   Click image for larger version.
ID:	24485   Click image for larger version.
ID:	24487   Click image for larger version.
    Re: CompARF 2.9m MXS / GP176evo
    First step tonight was to make up the proper thickness of hardwood donut stand-off.
    The standoff is a piece of birch and a piece of CF laminated plywood.
    22mm thick
    Will install motor tomorrow.
ID:	24489   Click image for larger version.
    So thankful my wife wanted decorative posts in this house LOL!
    After lining up the motor/standoff/spinner to the cowl, I got the stand-off installed with a fillet of Hysol 9462
ID:	24494   Click image for larger version.
ID:	24495   Click image for larger version.
ID:	24493   Click image for larger version.
    A few pictures of the GP176evo installed!!!
    Waiting on MTW exhaust order to arrive at Thunderboltrc.com, so will move on to other things next!
ID:	24497   Click image for larger version.
ID:	24498   Click image for larger version.
ID:	24499   Click image for larger version.
ID:	24500   Click image for larger version.
    Oh ya... forgot to show the LG install. I reeaaaallly like this new design by CompARF... gear is held on with bolts that clamp down CF bars! So instead of breaking the fuse, these CF bars can break. Sorta like the BVM sacrificial flex plates on the Jets
    Airman 5” wheels!!
    Wheels pants are molded to fit around the gear legs.
ID:	24502   Click image for larger version.
ID:	24503   Click image for larger version.
ID:	24504   Click image for larger version.
ID:	24505   Click image for larger version.
ID:	24507   Click image for larger version.
    Tailwheel is a Secraft Titanium unit.
    I inserted a hardpoint in the bottom of the rudder to anchor the steering spring
ID:	24509   Click image for larger version.
    Received: 114
    Nice Trev.
    This for yourself or someone else?
    None of these are for me Jim... been running my same fleet for years now LOL
    Reworked the tail wheel steering.
    Mockingbird steering shocks and a hardpoint with a CF bracket to get the geometry right.
ID:	24525   Click image for larger version.
    Rudder pull-pull is finished. 2 JR8911’s ganged together.
    Hopefully 1800oz-in is enough LOL
    Secraft pull-pull hardware from ThunderboltRc
ID:	24527   Click image for larger version.
ID:	24528   Click image for larger version.
ID:	24529   Click image for larger version.
ID:	24530   Click image for larger version.
