Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 42% Krill Lazer / GP176evo
    Next project for Peter Woo!!!
    Construction and finish on this is awesome!
    Getting into it tonight....
ID:	24387   Click image for larger version.
ID:	24388   Click image for larger version.
ID:	24389   Click image for larger version.
ID:	24390   Click image for larger version.
ID:	24392   Click image for larger version.
    Re: 42% Krill Lazer / GP176evo
    Got the cowl opened up. Really strange inlets for cylinder cooling. I think we will need temp sensors for this one - I’m a little suspect that these openings are enough for the GP176evo.
    Birch donut standoff depth = 24mm
ID:	24398   Click image for larger version.
ID:	24397   Click image for larger version.
ID:	24396   Click image for larger version.
ID:	24399   Click image for larger version.
    Got the engine positioned in the cowl and standoff Hysol’d to the firewall.
    Will mount the GP176evo tonight!!!
ID:	24402   Click image for larger version.
ID:	24403   Click image for larger version.
ID:	24404   Click image for larger version.
ID:	24405   Click image for larger version.
    GP176evo installed and MTW knuckle headers fab’d up!
    Tonight I will work on canister install!
ID:	24408   Click image for larger version.
    Went with MTW TDK-120 front exhaust cans. These fit perfectly in the fuse and the front exhaust will exit in perfect location.
    12” header length.
    http://thunderboltrc.com/index.php?m...oducts_id=1992
    Peter Woo
    Trevor maybe what we should do is open a square hole with rounded corners and bend and glue a thin aluminum lip to create some negative pressure to draw air through the engine on the bottom of the cowl
    Decided to support these TDK-120’s with 2 supports. To make it easier to install the exhaust the front can mount is a split unit!
ID:	24411   Click image for larger version.
ID:	24412   Click image for larger version.
ID:	24413   Click image for larger version.
ID:	24414   Click image for larger version.
    Quote Originally Posted by modelman992005 View Post
    Absolutely Peter... will do! Will get a baseline first without to see what temps we have and then go from there.
    Peter Woo
    I like the the install and the pipes coming out in front. Great job!
    Throttle servo install.
    Picture shows the rough box made up. Then went to town sanding on the drum sander until it fit tight against the inside of the mbox.
    Pictures are a bit deceiving... over 2” of clearance between end of arm and exhaust.
    Endpoints are close to+\-100% so good resolution!
    MKS 9737 Mini HV
ID:	24416   Click image for larger version.
ID:	24417   Click image for larger version.
There are currently 4 users browsing this thread. (0 members and 4 guests)
