Page 20 of 21 FirstFirst ... 1018192021 LastLast
Results 191 to 200 of 203
Thread: 42% Pilot Edge / GP176evo
  1. #191
    Re: 42% Pilot Edge / GP176evo
    Best way to line everything up is the stand it on its tail
    I’ve done this enough now that Jen doesn’t even comment, LOL.
    Just make sure you clean the oil off the bottom of the fuse... tough to get oil off the walls/posts
ID:	23650   Click image for larger version.
ID:	23651   Click image for larger version.
  2. #192
    Junior Member Demetri's Avatar
    Demetri Giokas
    Markham, ON
    JR
    Hey Trev, that’s very creative, but a little tricky...and you need a column...and a forgiving wife.
    Can’t remember who first posted it, but I like to use the wing tube between 2 ladders method. In the garage, I use a broomstick through the fuse, with a ladder on one side and a 6’ fridge on the other side. Just block the tail from moving between 2 boxes, suspends the entire plane with plenty of support.
    Can’t wait to see how the Edge will respond with the DA200. I have the PAU 40% Edge. Was planning on a GP176, but 4 cylinder might also be a nice option.
  3. #193
    Hey Demetri!! Awesome idea about the wingtube and ladders. Likely keeps a marriage a little more secure also LOL.
  4. #194
    Baffling done with CF plate
ID:	23655   Click image for larger version.
  5. #195
    The pipe tunnel on this plane is crazy low. Needs a 145mm drop for this DA200 and there’s no headers even close to that drop!
    So Brad Banville machined up these awesome units!! amazing workmanship!
    90mm headers + 55mm extensions = 145mm !!!!!
ID:	23657   Click image for larger version.
ID:	23658   Click image for larger version.
ID:	23659   Click image for larger version.
ID:	23660   Click image for larger version.
  6. #196
    I decided the finish under the canopy a bit...
ID:	23663   Click image for larger version.
  7. #197
    Senior Member carrid02's Avatar
    Craig Rideout
    Abilene, Texas
    Futaba, because of Jim
    Received: 37
    Looks awesome Trev. Beautiful scheme and great job fitting the DA200!
    -Craig
  8. #198
    Senior Member thaley's Avatar
    May 2017
    terry h
    kingston
    spectrum
    Love this one. the first time you built it was amazing, but I think I like this one better. Love the 4 banger. Good job sir.
    TreeD - Rainman
  9. #199
    Senior Member Buck Tracker's Avatar
    Dean
    Ponoka
    Received: 63
    Given: 154
    Cool beans Trev!
    Hey what is that clear fuel line you got there?
  10. #200
    Thanks guys!
    Dean... the clear line is a urethane tubing from I think SDS Hobbies... Jim buys it in bulk and sells 10m lengths.
