Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
Thread: BRAIN FART thread
  1. #41
    Senior Member -Snuts-'s Avatar
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Re: BRAIN FART thread
    Quote Originally Posted by Buck Tracker View Post
    WOW crazy, good thing that house blocked the path or he could have lost his sled!!!!!
    Oh the police would sure let him know where it ended-up, ha-ha.
    Brian, that is funny only because we can all get a real visual on that "Stunt".
    -Snuts-
  2. #42
    Senior Member OldPrairieRedNeck's Avatar
    Mervin Burkinshaw
    Coronation Alberta
    Hitec
    Received: 47
    I did it again! New radio, installed the reciever in a plane and checked out control throws - throttle good, elevator and rudder backwards - ok, fixed that. Now, out to the field to try it out - turned it all on - huh? No response, must have lost the bind? Took it all back home and rebound it. Checked the motor and elevator throw directions - still ok so the programming stayed right? Out on the front lawn this time and throttle up - off she comes - a bit of wind drift - right correction - hard left response - shmack!! Rudder backwards! Oh MAN!!!
    Had one of those but it broke!
  3. #43
    Max
    Quote Originally Posted by OldPrairieRedNeck View Post
    Dang Mervin! What were you thinking?
  4. #44
    Lloyd
    Received: 3
    Given: 16
    Tried to tell the wife she was WRONG! What was I thinking?
  5. #45
    Senior Member williame3590's Avatar
    Bill Allemang
    Caledonia, Ontario
    Received: 67
    Given: 99
    Quote Originally Posted by Wannabe View Post
    Yep, that's the dumbest one yet!
    I'll bet you only do that once.
    Bill
  6. #46
    Max
    Whoa!!! If you cant get that one right, there is no hope for you in RC.
  7. #47
    Member Rellic's Avatar
    Brian Tomlinson
    Vernon BC
    Received: 3
    Here is another non R/C but defiantly a prolonged well thought out Fart.
    Many years ago when I was Young and Bold I came across an older neighborhood gentleman on an uphill side road just a short way up off the main road I was driving on. It was late January well into our BC Interior snow season and He had attempted to drive up the side road a short distance and take His Dog out for some fun. Unfortunately He lost traction and slid backwards and off the road becoming STUCK. Me in My Macho Jacked Up Bronco decided to help the old fellow and His Dog back onto the road. I backed up the hill to just above Him and got out the tow strap, hooked onto the front of His frame and the tow hooks on Bronco, Told Him to put His Mercedes in neutral get His Dog out and stand clear while I pulled the car "UP" and out onto the "UPHILL" road. I then got Him and His Dog to get back in the car steer while I snubbed Him the short distance back down to the main road. End of story, refusal on My part for any gratuities or reward just a handshake and a neighborly know.
    Now the good part. the very next winter old fellow now has a BIG Ford Duelly and is heading UP the hill to the development He resides in and comes across a neighbor lady of His who due to driving ability and conditions has nosed Her half ton off the road on Her way "UP" the hill towards home. Being the good Samaritan He is He pulls up behind Her and offers to pull her vehicle back onto the road. I can only assume He remembered the procedure I used when rescuing Him because He told the Gal to put Her truck in neutral and stand aside out of harms way as He hooked up and proceeded to pull Her vehicle back DOWN onto the road and..........
    Brian T.
  8. #48
    Max
    Quote Originally Posted by Rellic View Post
    And BANG!!!
    Definitely a brain fart!
  9. #49
    Mervin Burkinshaw
    Coronation Alberta
    Hitec
    Received: 47
    Ok, I have been holding out on this one. Probably my dumbest brain fart EVER! Fession time!
    Not likely many of you remember the days when you used a hand crank to start a vehicle... well I still have one of those that I use to saw fire wood. #1 rule: it MUST be out of gear BEFORE starting is tried!
    I bet you didn't think I was still that quick on my feet eh?
Name:	amber's glider 008.jpg
  10. #50
    Dale Hunter
    Camrose, Alberta
    12X
    Received: 220
    Tough re-entry?
    -Snuts-
