Page 48 of 53 FirstFirst ... 384647484950 ... LastLast
Results 471 to 480 of 524
Thread: Aviation Design Diamond / Behotec 220
  1. #471
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Re: Aviation Design Diamond / Behotec 220
    OMG 3D modeling is IMPOSSIBLE!!! I got a lulzbot mini2 3D printer and im just trying to make a simple square-ish flat mounting plate with a 5mm thickness and the top edge being a little wider than the bottom so the taper fits the cockpit opening. (literally a flat square plate that is a trapezoid with 2 sides being parallel) I tried using Blender software and it is a NIGHTMARE to understand. I just want to tell the program how many mm i want everything and its mind altering trying to wrap my head around this even after half a dozen youtube tutorials which never quite explain exactly what you need for your project. Blender uses "blender units" and figuring out how to simply make an object X mm is way to complicated. Im a click and type in the dimensions kinda guy.
    Any software suggestions? Where do start?
  2. #472
    Rick Bruce
    Newmarket
    PowerBox Core; Futaba 14MZ; Spektrum DX18QQ
    I use Fusion 3D to design and Cura to upload. Marlin software on my Anet A8 and the stock on my Anet E10 Happy New Year
  3. #473
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Thanks Ricky! I crashed my diamond flew 1 lap around the pattern for a fairly low pass over the runway after decending from downwind at idle and then went full throttle but the turbine spooled up a little bit and then shut off so I was stuck heading towards the field and trying to gain a little altitude with what speed i had but couldn't make the turning it started to stall and came down at about a 30 degree nose-down angle and smashed in half. None of the Interior components or turbine were damaged so at least that's good but now I need a new one. Does anyone want to sell an airframe? It's going to probably take me a few months to buy a new one if I can get one on layaway.
    Happy new year!!!
  4. #474
    Rick Bruce
    Newmarket
    Oh no so sorry. Have a great New Year
  5. #475
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Okay I'm going to be purchasing a replacement diamond air frame. I was thinking either going with the gray with red vinyl like I had before, or maybe the orange sports scheme is the best. Any opinions on the best color scheme?
  6. #476
    Brent Holmes
    Southern Ontario
    FrSky Taranis and Horus, Futaba 9C
    Quote Originally Posted by brandom View Post
    Okay I'm going to be purchasing a diamond air frame. I was thinking either going with the gray with red vinyl like I had before, or maybe the orange sports team is the best. Any opinions on the best color scheme
    In my mind, the red and orange sport schemes are the nicest. IMO.
    TBrum has the red, and it is a nice metallic colour that contrasts well with the faux carbon accents.
    I have the orange Scorpion and I get a ton of compliments on the looks. The orange Diamond is the same colour.
    Again, just my opinion, but you asked!!
  7. #477
    Senior Member RC_MAN's Avatar
    Aug 2015
    PJD
    Ontario
    Futaba 18 MZ, Powerbox Core,
    The green one is hard to see especially in formation flying
  8. #478
    Rick Bruce
    Newmarket
    My Green one is so Beautiful
  9. #479
    Brent Holmes
    Southern Ontario
    It's not easy being green...........
  10. #480
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Well I called France and the owner of the company says he likes the orange the best
