Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 99
Thread: 120” Extreme Flight Bush Master
  1. #41
    Re: 120” Extreme Flight Bush Master
    Daaaaah 70 installed!
    Picked up the aluminum motor mount at Toledo... clean and easy!
    RPM and Temp telem. New plane, not sure how cooling will be so temperature telem is a must. Cheap insurance to protect the engine until I know cooling is fine!
ID:	22096   Click image for larger version.
  2. #42
    Throttle servo.
    MKS1240
  3. #43
    Senior Member Bhughes's Avatar
    Brodie
    Camrose AB
    Graupner mz-24
    Received: 392
    Given: 360
    Love the colours.
  4. #44
    Running the RE3 pipe at 8” headerlength.
    Had this exact setup in my EF MXS and it was dynamite! 600+ rpm increase and incredibly linear across the midrange! Closest thing to electric LOL
ID:	22098   Click image for larger version.
ID:	22099   Click image for larger version.
  5. #45
    Huge huge tunnel in this.
    So much space to work... never had setup this easy
ID:	22105   Click image for larger version.
ID:	22106   Click image for larger version.
ID:	22104   Click image for larger version.
ID:	22103   Click image for larger version.
  6. #46
    So the cowl has no air inlets. Weird. Instructions show how to do the cutouts and talk about installing a lip to suck the air out.
    The spinner is smaller than the hole, so air will go in there. Not sure if enough. Will watch temp telem for first flights and see. Worst case I will cut 2 round inlets in front of the cowl and do ducting to each cylinder.
    DA70 is a tight fit. Crazy how the cowl narrows down so quick at the front.
ID:	22107   Click image for larger version.
ID:	22108   Click image for larger version.
ID:	22109   Click image for larger version.
ID:	22110   Click image for larger version.
  7. #47
    Fake turboprop exhaust outlets installed!....
ID:	22112   Click image for larger version.
ID:	22113   Click image for larger version.
ID:	22114   Click image for larger version.
  8. #48
    Received: 22
    Yeah don't like that cooling system . I'd at least be cutting some vertical slots in front of the heads .
  9. #49
    Ya it tapers significantly as it's modelled after the turbine powered Turbo Beaver, which has a PT-6 turbine on the full scale..
    I just did the cowl cutting as they suggested and like you I've got the MT300 for head temp monitoring. What temp would you set your alarm at in the Jeti?
    Also I didn't bother with that air dump flap thingy.....mmmmm, got me thinking....
  10. #50
    Senior Member -Rick-'s Avatar
    Rick
    Chesley Ontario
    Horus
    Received: 50
    Given: 68
    Two tiny EDF fans in the exhaust tubes. (Chuckle chuckle)
