Page 39 of 92 FirstFirst ... 2937383940414989 ... LastLast
Results 381 to 390 of 920
Thread: Giant Stearman / Moki250 Build
  1. #381
    Re: Giant Stearman / Moki250 Build
    With the fuse construction done, I just started into mounting the upper center wing section.
    Pretty straight forward. Nicely explained. Easy to follow.
    A front and a back temporary cradle. Puts the upper center section at 0deg incidence to the fuse.
  2. #382
    Cabane struts cut to length, drilled and bolts installed.
    Just takes some time... lots of compound angles at the end of each strut
ID:	20837   Click image for larger version.
ID:	20838   Click image for larger version.
  3. #383
    And “X” flying wires done. One end is Silver Soldered (40% Ag, Map Gas) and the other end is threaded.
    Dirt easy. This is a very fun part of the build!!
ID:	20840   Click image for larger version.
  4. #384
    Mike H
    JR
    You mentioned Hysol glue, what kind of hysol are you using? Nice looking build!
  5. #385
    Quote Originally Posted by Mikeh View Post
    Thanks!
    Hysol 9462 is like a creamy white. Takes about 12hr to cure but insane stuff
  6. #386
    Got the 4 front flying wires
    Holy Cow! That upper center section is craaaazy rigid!!!
ID:	20842   Click image for larger version.
  7. #387
    That’s because it’s been strengthened and reengineered by the meistro himself 😜...lol
    Looks great and amazing progress👍
  8. #388
    Mike H
    JR
    Thanks!
    Thanks man!
  9. #389
    Ha. Eric.. not many mods on this project. If I build a second, i’ll try to think a bit outside the box... depends how quick this one does a spinner dip!!
  10. #390
    Senior Member Flyin High's Avatar
    Jun 2015
    Bob S
    Beeton, ON.
    Received: 166
    Given: 192
    Lol! You’ll baby it! It has your precious Moki up front.
    Looking awesome!!
