Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Falcon vs Mejzlik Props
    Hey gents,
    I've recently bought a few Falcon carbon props that had hubs way out of balance, at least by my standard. I would like to try Mejzlik. What I'm curious about is how they compare for load. I know the Falcon 24x9 is about right on my GP61, would the Mejzlik 24x9 be about the same? How about the thin props, what would be the expected advantage/disadvantage?
    Thanks!
    Member Jason T's Avatar
    Feb 2016
    Jason Thompson
    Sudbury
    DX9 / Tactic 650
    Re: Falcon vs Mejzlik Props
    I can only add that I do not think I will be buying any more Falcon props either. Between center holes off (wood props) and bad hub balance on cf,..I think i'll spend my money elsewhere.
    I found Xoar cf to be good as well, But Mejzlik seem to be the best quality / value in Carbon.
    Quote Originally Posted by Jason T View Post
    I can only add that I do not think I will be buying any more Falcon props either. Between center holes off (wood props) and bad hub balance on cf,..I found Xoar cf to be good as well, But Mejzlik seem to be the best quality / value in Carbon.
    That's been about my experience with Falcon, but probably only the last two years or so. The first few carbon props I bought from them were great.
    Now that you mention Xoar, I have a couple of their wood props that were balanced dead on both hub and blades right out of the package. It's too bad they never seem to be in stock where I normally shop and they have limited different pitches available...it looks like the only make a 24x10 in carbon.
    wingburner
    3 Not allowed!
    Chintz vs Mejzlik??
    No contest....Mejzlik for me thanks!!
    Feb 2016
    Jason Thompson
    Sudbury
    DX9 / Tactic 650
    I am trying to decide on new Carbon Fiber prop for a DA100. Will most likely go with a Mejzlik, just not sure on size yet.
    I have a borrowed Xoar 27x10 cf on there now, but not quite enough. Anyway, it will not be a Falcon unless i can see it, balance it, and see that it fits first before buying. Ha!!
    Hanes E
    Received: 32
    Given: 42
    Mejzlik 27x10 cf the bomb for a da100. Works well on cans or tuned pipes. Luv it on my pitts.
    Senior Member rpm's Avatar
    Paul M
    Woodbridge, ON
    Futaba 18MZ, Jeti DS-16
    Received: 56
    Given: 58
    I've never had a real problem with a Falcon prop but Mejzlik do seem to be of higher quality. I found out last year while ordering a couple of large 3 blades direct from Mejzlik in Czechoslovakia that they prepay the shipping on orders over a certain value. It was a very pleasant surprise and the package arrived efficiently and there was nothing (HST + handling) due on receipt.
    Humber Valley RC Flyers
    Feb 2016
    Jason Thompson
    Sudbury
    DX9 / Tactic 650
    Quote Originally Posted by Old School View Post
    Thanks, I will have to find one and give it a try.
    Received: 114
    Jason do you have the older DA100 or the newer DA100L?
    The 100L Likes a 28” x 8” CF prop
    Feb 2016
    Jason Thompson
    Sudbury
    DX9 / Tactic 650
    Hi Jim, it's the older version. Only 3 flights, but its a sweetheart of an engine. Think i'm going to try a Mejzlik 27x10 if i cant find one ill order one up. I have it running ritch at the moment, until i get some more flights on it. I bought it used, but it was sent to da before I purchased it. Rips the Xoar 27x10.
