Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 116
Thread: Tamjet 1/8 F16 MakeOver!!
    Re: Tamjet 1/8 F16 MakeOver!!
    The front end was missing 2 formers... gutted the front, installed new formers and made up an equipment tray!
    Soon I will sand the interior and paint / sparkle the inside to freshen everything up.
ID:	17491   Click image for larger version.
    Rehinged front gear door. Works smooth and free now and closes flush.
    Will rehinge main doors tonight. Sets me up well to soon start bodywork to tighten up all gaps and bring it back to new condition.
ID:	17492   Click image for larger version.
    Rick Bruce
    Newmarket
    PowerBox Core; Futaba 14MZ; Spektrum DX18QQ
    Nice work Trev......I could have printed that engine Holder on my 3D Printer.....not sure what Temp ABS can take how ever.....PLA no way......I have 2 printers now
    Wow... you are really going hardcore on the 3D printer!!
    I might pick your brain on the printer - was thinking of dabbling with a unit later this spring. Sure is cool the stuff you can do with them.
    Been working with Callie at Callie Graphics for all the markings for the Alaskan Aggressor F16 Scheme.
    She is top notch Turns out that she had the markings on file.
    She is making me up paint masks for this project!!
ID:	17494   Click image for larger version.
ID:	17496   Click image for larger version.
    Gear installed, doors rehinged and fitting better.
    Small stuff... getting me closer to starting the bodywork and finishing!
ID:	17503   Click image for larger version.
ID:	17504   Click image for larger version.
    Tams pipe and Jet Central Rabbit installed. Figured it was better to start with a clean slate and get everything lined up and centered.
ID:	17507   Click image for larger version.
ID:	17508   Click image for larger version.
    Had to repair the intake plenum. Wrapped the cracked area with CF. Super strong now.
    Should look good once the inside of the fuse and intake is all painted
ID:	17509   Click image for larger version.
    2 saddle tanks and a main header tank give this exactly 2L of fuel.
    Just used Jen’s measuring cup and ruined it... oops . Can’t get the smell of JetA out if it!!. Gonna have to make a trip to Walmart tomorrow!!
    Threw out the rubber stoppers. Will rebuild these with metal fittings later
ID:	17511   Click image for larger version.
    Got the plane stripped and painted a dark automotive grey on inside with my airbrush. Dusted the dark grey with spackle paint.
    Looks nice and clean again
    Next I need to sand the exterior down and do bodywork... couple weeks worth of work there
ID:	17513   Click image for larger version.
ID:	17514   Click image for larger version.
ID:	17515   Click image for larger version.
ID:	17516   Click image for larger version.
