Received: 32 Given: 42 |
Thanks steve. Ed was telling me how awesome these are
EDIT : having a hard time find the NG model"? What sizes do you suggest for indoor 32inch. ?
Received: 97 Given: 87 |
I think NG was what they called the EPP version when they still sold the Depron version. Steve will correct me if I'm wrong but I think what you want is the Clik R2 Superlite...I believe it is the latest iteration of the NG.
https://twistedhobbys.com/th-33-epp-...per-lite-blue/
https://buyrc.ca/airplanes/airplanes...lite-blue.html
Received: 214 Given: 74 |
No
You don't want that unless you never have mid air with wall, floor, other plane.... There is a difference between the materials and after building the R2 and having built 8 to 10 NG it is obvious they will out last the R2.
I have built NG versions as low as 99 grams, as high as 113 grams with a 2204. Standard build of R2 at about 125 grams with the higher powered motor from the thrust vectoring Edge.
Hey, Sorry to bother again, but I cannot seem to locate anything with NG, other then their larger airfoils series FLASH
Is this the one? I get more hangar rash then anything, so stronger is better
https://twistedhobbys.com/rcf-36-epp-flash-ng/
Edit :I have a 32” vivko edge with aix 2204 power in it was hoping for a little slower. This thing is a monster with outdoor power
Its not the same, I assume a different product to be lighter.
Received: 0 Given: 0 |
looks like your videos have been taken down by youtube!!?
