Page 29 of 33 FirstFirst ... 192728293031 ... LastLast
Results 281 to 290 of 323
Thread: Flex Innovations Mamba not built by me (but i coulda)
  1. #281
    Senior Member Machzx's Avatar
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    Re: Flex Innovations Mamba not built by me (but i coulda)
    ready yet
  2. #282
    Quote Originally Posted by Machzx View Post
    ready yet
    Shake down and maiden today! DA70 is phenomenal and the Mamba seems pretty great. I had steady crosswind of ~25km/h and gusting to about ~40km/h, between that and not wanting to beat on my brand new engine too much I didn't get a real great feel for the airframe. I'll get it all dialled in on a warmer/calmer day and get a better feel for it.
    First run vid: https://goo.gl/photos/i2aYjL39Y94cHASp6
ID:	14023   Click image for larger version.
ID:	14024   Click image for larger version.
  3. #283
    Received: 114
    Quote Originally Posted by Cosmith View Post
    Congrats Corey but it's a DA no need to Baby it. LOL
  4. #284
    Quote Originally Posted by JDaly View Post
    I'm sure you're right Jim. I just feel better with any engine letting the rings seat and keeping the temps down until things loosen up a bit. Definitely won't be doing the 10 gallon mega rich half throttle only super break in that some people think is required...just treating my investment with a little respect!
  5. #285
    Aug 2016
    Chris
    18MZ
    Where is the snow? sooo jealous.
  6. #286
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    meh mine got a proper beating !!!
    cant hurt them
  7. #287
    Aug 2016
    Chris
    18MZ
    Just Finished mine 21lbs with da70.
    So a few issue one of the inter-plane struts is wrong 20mm gap instead of 15mm, quite unimpressed about this one.
    On the one that do line up will need a big pair of pliers to install and remove them.
    All covering was shrunk, but in some spots it looked like I did it (not very good).
    The canopy is almost impossible to install the fit is horrendous.
    For an arf of this price I did expect a bit more.
ID:	15324   Click image for larger version.
  8. #288
    Ed
    Sutton
    Futaba 18mz
    Received: 528
    Given: 511
    Send email to flex with pics
    I've had nothing but good service from them
    I'm in town too Chris
    Text me
  9. #289
    Quote Originally Posted by chrispol View Post
    I had the same sorts of issues. Exact same interplane strut fit issue. I had a feeling the canopy latch was inadequate and mine let go after about half a dozen flights. I'm still using pliers on all but one of the strut pins, and that one requires tape to stay in. I personally wasn't impressed with some of the hardware and there were problems with my rudder hinging. If I did it over again I would glue the strut blocks into the wings with the plane fully assembled. I did a test for and it seemed fine but after I glued it I ran into the same issue you have... seems like just the one block goes to deep into the wing.
    I have to say though, once I flew it I forget about the little flaws. The airframe is amazing to fly, your going to love it.
    ****Make sure you loctite the servo arm screws and check them frequently. The arms are a very sloppy fit on the spline and like to loosen. Did you flip the servo mounting grommet inserts?
  10. #290
    Aug 2016
    Chris
    18MZ
    So did you just trim the other inter plane strut? I guess could try and peel back the covering and trim it
    loctited the crews some were not even in all they way.
