Page 12 of 14 FirstFirst ... 21011121314 LastLast
Results 111 to 120 of 137
Thread: Oldie but a goodie - Skymaster F-15 build
  1. #111
    Senior Member DHC8's Avatar
    Louis
    Limoges
    Re: Oldie but a goodie - Skymaster F-15 build
    Quote Originally Posted by Myzee View Post
    If it's ok, Id like to ask you a question about your F-15.
    Elevator servos---I see there are holes in the wood inside the elevator access area. Are these blind nuts to mount the servos?
    I have absolutely no instructions with mine and can't find a manual so I hope you don't mind me asking some questions!
    Myles,
    Unfortunatly no blind nuts. I would move the servo just a bit and use fresh wood. The kit comes with a hole pile of good wood screws. I marked the holes and some small pilot holes, then used the wood screw to make the hole. THen dropped some CA down the hole. They held in VERY strong. The elevators were ripped off in the crash and the servo's were still in there solid.
  2. #112
    Louis
    Limoges
    Quote Originally Posted by FrankW View Post
    I would be interested in the struts.
    Sorry all parts have been sold.
  3. #113
    Senior Member Myzee's Avatar
    Jun 2016
    Myles Jarvis
    Picton, Ontario
    Futaba 14SG, 9C
    Ahh, ok gotcha. Yeah mine has no screws but thats no problem. The wood seems a little thin so I will double it.
  4. #114
    Mar 2016
    lucky macy
    futaba
    Quote Originally Posted by DHC8 View Post
    That was fast! What website did you use?
  5. #115
    Louis
    Limoges
    Quote Originally Posted by lucky View Post
    RC Canada
  6. #116
    Jun 2016
    Myles Jarvis
    Picton, Ontario
    Futaba 14SG, 9C
    I keep forgetting to say...Man, that balance and weight machine you used here is sick!!!
    I never seen one before until this thread.
  7. #117
    Louis
    Limoges
    Myles,
    It's the Xicoy CG balancer. Works AMAZING! Jet pilots best friend. Doing the CG on these jets can sometimes be a real PIA, this device makes it a much easier. Very accurate, and you also are able to balance laterally as well. Awesome device!
  8. #118
    Jun 2016
    Myles Jarvis
    Picton, Ontario
    Futaba 14SG, 9C
    I saw that on the display, can see the lateral weights, thats so cool!
  9. #119
    Jun 2016
    Myles Jarvis
    Picton, Ontario
    Futaba 14SG, 9C
    Being a full flying stab I would think they should be balanced, did you balance yours? Mine are quite tail heavy
  10. #120
    Louis
    Limoges
    That was next on the to-do list. I got some lead shot to do it, but didn't get to it. With over 600oz of torque on each stab I wasn't immediately concerned with the weight balance of the stab.
