Received: 987 Given: 745 |
Peter W and I got a pair of these Pegase Composites Akuma planes.
I am building mine first and then will likely build Peter’s once I figure all of this out and test fly mine!
We got these through Chad Northeast. Chad has a really cool build series on YouTube that I am using. They are a ton of work and aren’t really much different than building a Carden.
Excited about getting back to wood and Monokote!!
Here is Chad’s video series for the build
Here are a few pictures of the fuse build. Chad goes into all the detail on his build videos so I won’t bore anyone repeating it.
A summary…
1) aft bulkhead install in fuse shell
2) stab tube phenolic install
3) stab anti rotation pin
4) wing tube phenolic install
Tons of work here. Probably have a good 10-15hr of build time into these details. Tons of alignment, measuring, laser level work.
Got the rear rudder post fab’d, glued in with Hysol and bevelled. I also lightened it to save about 12grams
Received: 11 Given: 1 |
Cool project
I got the fuse painted! Automotive base / clear! Turned out really well. I did 1 coat of clear to keep it as light as possible!
So the Akuma kit comes with CF landing gear but I decided to order the new Falcon CF gear and Falcon CF wheel pants from F3AUnlimited. Axles and wheels are from Morris Hobbies
The bulkhead for the gear assembled well and only required minor shaping. All glued in with Hysol of course
Equipment Links
Landing Gear – Falcon + wheel pants CGL-101
https://www.f3aunlimited.com/landing...s-black-falcon
Axles – steel spring loaded – Japan
https://morris-hobby.securesite.jp/51_442.html
Main wheels for the spring loaded axles – cannot use Dubro etc. these are sold individually so you need 2
https://morris-hobby.securesite.jp/20_439.html
Tailwheel frame installed..
Equipment Links
Tailwheel Frame – Nishioka – does not include the wheel
https://morris-hobby.securesite.jp/31_185.html
Tailwheel
https://morris-hobby.securesite.jp/22_67.html
Received: 114 Given: 14 |
So Move to the WC and get corrupted? Switch from Huckin to Pattern?
Sad times indeed!![]()
Received: 214 Given: 74 |
Like when Jim went from Huckin to IMAC, so sad
lol
LOL. When did you fly last Jim???
Darn Covid
