Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: CompARF Extra 330LX / DA200
    Received: 11
    Re: CompARF Extra 330LX / DA200
    Nice work Trev👍
    Come to think of it, Andy had to cut in the offset on my 330SC as well....seems a bit bogus they don’t do that at the factory
    Ya Eric... they could have done it a lot different to make this an easier build.
    But alas!
    Got the 2 ignitions and the Jeti telemetry installed!!
    * 2 x MT300 sensors (so temp on 4 heads)
    * 1 x MRPM sensor
ID:	25462   Click image for larger version.
    The kit doesn’t come with any sort of canister holders so made up a custom one that fit in the tunnel. Hysol’d it in place and got the 2 x MTW110 cans installed!
    Also got cooling holes in the tunnel
ID:	25464   Click image for larger version.
ID:	25465   Click image for larger version.
ID:	25466   Click image for larger version.
    Prop (Falcon 30x13W) and Spinner (Falcon 6”) drilled out.
    Onto the baffling tonight!!
ID:	25475   Click image for larger version.
ID:	25476   Click image for larger version.
    Peter Woo
    Trevor you are doing a great job with the install. Thank you so much !
    Got the side rails cut out of 1mm CF plate and hysol’d to lower cowl...
    Here’s some pics of the main baffles...
ID:	25491   Click image for larger version.
ID:	25492   Click image for larger version.
ID:	25493   Click image for larger version.
ID:	25494   Click image for larger version.
    With the engine bay all finished, I got the wheel pants / axles and sweet aluminum WhiteRose wheels installed!
ID:	25504   Click image for larger version.
ID:	25505   Click image for larger version.
    And thanks to Craig R, the Mockingbird tail wheel spring system arrived!!!
    Absolutely love these units - thanks Craig!!
