Yep, this is the crimping tool: http://www.thunderboltrc.com/index.p...roducts_id=280
And everything else you need can be found here: http://www.thunderboltrc.com/index.p...index&cPath=82
You just buy bulk wire in the gauge of your choice and whichever connectors you choose. I keep quite a bit "in stock" just in case a need arises.
It took me a few tries to get nice solid crimps that I was happy with, but once you figure it out you're good to go. I've found the smaller the wire gauge the easier it is to work with. The 20awg silicone shielded wire is tough to get into the connectors, but worth it if you are doing long runs with high draw servos.
