Page 46 of 48 FirstFirst ... 364445464748 LastLast
Results 451 to 460 of 474
Thread: Aviation Design Diamond / Behotec 220
  1. #451
    Apr 2017
    Brandon W
    St. Louis
    Jeti DS-24
    Re: Aviation Design Diamond / Behotec 220
    Cool thanks for the info Jeff. I hadn’t thought of that. I originally thought it would work best in the wing leading edge but then you would have to take the connection apart every time you remove the wing. The vert stab will be staying on...
  2. #452
    Jul 2016
    Brandon
    Weatronic and Futaba
    Well the diamond is almost ready and when I got the vertical stabilizer attached it is able to move right and left a little bit because cradle the aluminum tube sits in right above the turbine does not tightly contain the tube. There is probably a 16th of an inch before it hits the plywood that is designed to hold it laterally. I wonder if anyone else had this problem. This slight movement translates to quite a bit by the time it reaches the top of the vertical stab. I guess I will glue some plywood squares in next to the tube to hold it tight.
  3. #453
    Jul 2016
    Brandon
    Actually there looks like quite a bit of space but maybe it's stopping from whatever is holding it above where I can see in the wing tube shroud. Who knows
  4. #454
    Junior Member Jeffdec's Avatar
    Jeff DeCaluwe
    London, Ontario
    Spectrum, JR, Jeti and Futaba
    Hello again Brandon,
    Rick Bruce used wood dowels in his tubes for extra strength maybe you could to to make up the space
    Flying in the sky is definitely better than flying in the ground.
    Maac 70110
    Jeff D
  5. #455
    Rick Bruce
    Futaba and Spektrum
    Yes I did.....hi Jeff
  6. #456
    Jul 2016
    Brandon
    Oh okay thanks for the reply I think I will do that. I'll take a look back through the posts if it's in there
  7. #457
    Jul 2016
    Brandon
    Hey Ricky hows it going? Did you take any pics of the dowel installation?
  8. #458
    Rick Bruce
    Futaba and Spektrum
    I can get you one
  9. #459
    Jul 2016
    Brandon
    Great thanks!
  10. #460
    Rick Bruce
    Futaba and Spektrum
    Here you go
