Page 263 of 273 FirstFirst ... 163213253261262263264265 ... LastLast
Results 2,621 to 2,630 of 2722
Thread: Badan Vertigo 2M Build Thread!!
  1. #2621
    Senior Member Carlisler's Avatar
    Scott B
    Received: 307
    Given: 439
    Re: Badan Vertigo 2M Build Thread!!
    I found that the rod can leave an indentation on the fusenside and if left alone, would probably puncture the monokote and move into the thin balsa sheeting and foam in the fuse.
    I cut a thin piece of Delrin rod and double sided taped it to the fuse at the rod location.
    Like Trevor said, the other side has the hard ply of the side force generators to keep it there. So it isn’t moving there.
    No matter if you use any of these ideas, if the rods inside the aileron do not almost completely fill the gap between root and tip, they will work themselves out of those root and tip supports/hangers and create flutter.
    Cheers
  2. #2622
    Apr 2017
    Tim R
    Germany
    Where do you guys have the CG of your Vertigos?
    Middle of the wingtube?
  3. #2623
    Senior Member oachidori's Avatar
    Jan 2016
    Diaconescu Olivian
    Bucharest
    Multiplex Royal SX16
    Received: 8
    Mine, is just behind of the middle of the wingtube, and it s ok.
    Badan - YAK 55M 2.8m; EF - Extra 300S 2.3m; Multiplex - Funcub 1.4m; Funjet Extra; Robbe - Mistral 2.0; Freewing - F22 90mm EDF
  4. #2624
    Mine is at the TE of the wing tube - completely neutral inverted or right side up on level flight.
  5. #2625
    Apr 2017
    Tim R
    Germany
    Thank you!!
  6. #2626
    Received: 114
    Given: 14
    Quote Originally Posted by Carlisler View Post
    Cheers
    Well that seems like a built-in failure. WTF?
  7. #2627
    Apr 2017
    Tim R
    Germany
    I extended the rods so that they exactly fit the gap. Furthermore I glued a screw in the rod to the tip side which I can screw into a nut which is integrated in the tip.
    So the rod is fixed and can not move out at all ...
  8. #2628
    Quote Originally Posted by JDaly View Post
    Jim... you had better slow down on yours and rethink this for a few weeks!!!
  9. #2629
    Jan 2016
    Diaconescu Olivian
    Bucharest
    Received: 8
    I have finished the rebuild of the Vertigo. Many thanks to Dan for help.
  10. #2630
    Scott B
    Received: 307
    Given: 439
    Congrats Oachi!!
    I am nearing completion of a second vertigo for a friend.
    Must build wings, with mods.....
There are currently 30 users browsing this thread. (0 members and 30 guests)
