Page 254 of 272 FirstFirst ... 154204244252253254255256264 ... LastLast
Results 2,531 to 2,540 of 2716
Thread: Badan Vertigo 2M Build Thread!!
  1. #2531
    Senior Member Carlisler's Avatar
    Scott B
    Received: 299
    Given: 438
    Re: Badan Vertigo 2M Build Thread!!
    Quote Originally Posted by badan View Post
    guys, if you will have some Vertigos spamming weekend .-) share photos please.
    Scott, yes, more work to finish with that slim vinyl, but worth for it, looks nice
    Yes, those vinyl sheets are thin and easy to work!
    I was surprised at how easy it is to use them.
    Line them up properly, and use the hinge technique, and they go on very quickly. The level of effort:result ratio is incredibly high with these large stickers!
    There is the little additions that must be attended to, but those are fairly easy. (the white extensions on the cowl and hatch.)
    But the overall lines in this scheme are sexy!
    And I love the 'Bengal Tiger' look of the cowl!! (didn't fully see that until it was right in front of me and complete....LOL)
  2. #2532
    Feb 2017
    doug wil
    Looks awesome!
  3. #2533
    Apr 2017
    Tim R
    Germany
    Scott, that design is awesome! I love it!
    I am planning to do the same, but in Racing Green.
    But it will take some time until I will be at the point to start with the design ... hehe.
    I also started to build my Vertigo and opened a thread to promote the Vertigo a bit more in Germany:
    http://www.rc-network.de/forum/showt...-airplane-kits
    I am currently thinking about motor mount position.
    I saw in the motor mount plate there is a little hole … am i right that this was drilled to indicate the center position for mounting the motor?
    I am thinking to use a DLA56 motor with the standard standoffs… what ist the optimal motor length you guys used in your Vertigos?
    I mean the distance between motor mount plate and spinner back plate...
  4. #2534
    Scott, great job! That may just be the best looking plane I've seen...totally awesome.
  5. #2535
    Received: 113
    Quote Originally Posted by Schnubbi View Post
    I am thinking to use a DLA56 motor with the standard standoffs… what is the optimal motor length you guys used in your Vertigos?
    Tim that would be hard to give you a definitive dimension as each Motor has different dimension from
    back of the mounting lugs to the front surface of the engine thrust washer.
    If you measure the distance specified above on your particular engine you should then be able to transfer that dimension on to the plans and calculate the stand-off dimension.
    OH and Tim I called the Kawasaki Green colour scheme so Back off! LOL!
  6. #2536
    Received: 113
    Quote Originally Posted by Cosmith View Post
    Corey am I sensing a bit of Seller Remorse about letting your Vertigo go?
  7. #2537
    Apr 2017
    Tim R
    Germany
    Quote Originally Posted by JDaly View Post
    I would love to do so, but I have no exact plans which I can use as reference for the calculation...
    Do you have one?
    And don't worry about the design ... as you are on a different continent, that shouldn't be an issue! ;-)
  8. #2538
    Received: 113
    Do you have one?
    Tim,
    OH no plans?
    Haven't checked my kit yet.
    Well I guess you will have to take your engine dimensions and measure from the firewall to the front of your cowl to get a rough idea then maybe try an make some temp standoffs using dowels and play wit them to get exact dimensions.
    I was just yanking your chain about colour scheme. No one has exclusive rights to any scheme. LOL!
    How close to starting are you?
  9. #2539
    Apr 2017
    Tim R
    Germany
    Yep, no plans. :-)
    The only plan I could find is in the Badan Gallery, but there the resolution is too small to get those details.
    You can see my current status here:
    (at least on the pictures :-) )
    That little drilled hole in the motor mount plate should be the motor center (hopefully) ... so I will drill the holes for mounting the motor accordingly ...
    And the size of standoffs I can check later then ...
  10. #2540
    Scott B
    Received: 299
    Given: 438
    Yes. That hole is offset for the motor angle.
