Page 176 of 272 FirstFirst ... 76126166174175176177178186226 ... LastLast
Results 1,751 to 1,760 of 2716
Thread: Badan Vertigo 2M Build Thread!!
  1. #1751
    Senior Member tbrum's Avatar
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 982
    Given: 745
    Re: Badan Vertigo 2M Build Thread!!
    Thomas... those servos are way too weak for this plane. Keep in mind that the aileron is 1/3 of the entire wing. I woukdn't be flying with less than 400oz-in in each wing.
    My servos are 520oz-in and borderline at high speeds. Ed's at 700 are much better.
  2. #1752
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 982
    Given: 745
    Also.. my 3M started with (2) 520oz-in servos per aileron which is usually fine for any equivalent size Carden or ARF. Waay too weak. Above 1/2 throttle it would roll soo slow.
    Add a 3rd 520 oz to each wing and much much better.
    Ailerons take tons of power
  3. #1753
    Member
    Oct 2015
    thomas jackson
    spektrum
    Received: 5
    Quote Originally Posted by tbrum View Post
    What servo would you recommend? I'm not set-up for HV - am running a 2s LiFE (actually two for redundancy) to about 6v through the receiver to the servo.
  4. #1754
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 982
    Given: 745
    Pretty sure that Savox has some low voltage servos that have over 400oz-in at 6V.
    MKS does also. Pretty sure the BlueBird specs are impressive at 6V also. Futaba does.
    I'll get you some numbers soon.
    100% guarantee the flutter is those poor little 277oz-in servos hanging on for dear life.
  5. #1755
    Member
    Oct 2015
    thomas jackson
    spektrum
    Received: 5
    I'm using the same all around - rudder, elevators. Didn't notice any issues with those surfaces. Do you think they are ok?
  6. #1756
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 982
    Given: 745
    Elevators don't take much power, so 277 is more than fine. Rudder should be okay for general sport flying but I doubt it will have the power to do a KE loop for exemple
  7. #1757
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 982
    Given: 745
    Quote Originally Posted by jacksontd View Post
    Had good luck with the Savox 1283. Savox1230 or 1231 work, however have seen a few develop slop.
    The MKS DS1220's are beautiful with an amazing gear train.
    Ed has the Bluebird H50C's... Not much experience but whicked specs and seems to work well on the 2 flights on his Vertigo. A few other non-helical Bluebirds that will work. No first hand experience on longevity, but many good reports
    Futaba has a couple SBUS options that would work.
    I'm bias toward Futaba and MKS, but just me. Ford vs Dodge vs Chevy, LOL
  8. #1758
    Member
    Oct 2015
    thomas jackson
    spektrum
    Received: 5
    Had good luck with the Savox 1283. . . . The MKS DS1220's are beautiful with an amazing gear train.
    So between these two, it looks like the Savox is a bit more powerful at 417 oz at 6.0v. The DS1220 is 422 oz at 6.6v., but only 346 oz at 6.0v. I'm leaning toward the Savox for the extra power. What do you think?
  9. #1759
    Senior Member JDaly's Avatar
    Jim Daly
    Mississauga ON EH!
    JETI
    Received: 113
    Given: 14
    3 (100%)
    Ford vs Dodge vs Chevy?
    Ithought you were an Acura and Honda guy? LOL
  10. #1760
    - Trusted Vendor -
    Apr 2015
    dan
    Received: 14
    Very good experiences with Savox 1270, powered with 2S Li-Pol
There are currently 4 users browsing this thread. (0 members and 4 guests)
