Page 1 of 36 12311 ... LastLast
Results 1 to 10 of 352
Thread: Gyros 4 AirPlanes
    Senior Member Pete's Avatar
    Peter Lock
    Winfield / Buck Lake, Alberta
    Spektrum DX9 / DX7s
    Received: 274
    Given: 269
    Gyros 4 AirPlanes
    Here is a video for the “Bavarian Demon Cortex” very easy to set up in a plane.
    Pete
    Valley Model Aeronautics Club / Drayton Valley, AB
    Trout Farm Flyers / Camrose, AB
    Alberta's Littlest Airport / Bawlf, AB
    "Project PINK"
    Re: Gyros 4 AirPlanes
    Ya Pete. The nice thing with the Cortex is you plug in the leads in any combination of aileron, elev and rudder. Then the instructions walk you through a sequence of stick movements you do on the transmitter with plane turned on and the Cortex learns the system. Very sweet.
    The new little iGyro 3e is a sweet little unit also... I'll be doing the final setup on one soon.
    I also have the larger iGyro with the integrated GPS in 2 of my jets... the speed compensation for gain sensitivity is a whicked feature and really shows on the jets.
    Peter Lock
    Spektrum DX9 / DX7s
    Received: 274
    Given: 269
    The iGyro is beyond my budget.
    Pete
    Pete.. the smaller iGyro 3e is cheaper than the Cortex... go check them out at Altecare.com
    Senior Member reo's Avatar
    Ron O
    Millet, Alberta
    Received: 178
    Given: 88
    can't find any gyros on Altecare's site, plus there's no search feature either
    Trout Farm Flyers
    Just put a Cortex in my 35cc Redwing Slick. I'm also running a few of the Lemon RX stabilizers in my electric planes and I've been very happy with them. I can see a few differences between the way the Cortex and Lemon stabilizers operate on the ground...one thing is the way the Cortex slowly returns a control surface to neutral even if the surface hasn't returned to it's pre movement position. Obviously the software in the Cortex is more sophisticated.
    I'm anxious to get them both in the air to see how they compare...obviously the price difference is massive. However, the Lemon RX units can't be used in a fuel powered planes anyway.
    The iGyro sounds pretty similar to the Cortex...just reading a review on rcuniverse. Looks like US vendors are selling it for about $215. It will certainly be worth looking at for anyone in the market for a Cortex...I've already spent the big bucks unfortunately!
    Just found the iGyro 3e on Altecare for $235 USD...significantly cheaper than Cortex.
    Also, it apparently allows you to independently adjust gain on each channel, don't believe the Cortex allows that?
    Sounds like there are some other advantages like drawing power on each channel from the RX...I understand this could be important on larger planes?
    Looks like it could be a winner...I wonder how the software compares, I think that will play the biggest role in how intrusive the gyro is, especially in higher energy stuff like tumbles.
    Ya Cory... some neat stuff in the iGyro 3e. I have one partially installed and so far it works just like the larger iGryo with the speed compensation. I have played with the Cortex and if you plug it into your computer, you can adjust the gain of each channel as well as the latching.
    Peter Lock
    Spektrum DX9 / DX7s
    Received: 274
    Given: 269
    Could not find a setup video for the iGyro 3e, many for the iGyro srs. For me I would prefer keeping things simple if possible.
    Pete
    Quote Originally Posted by Pete View Post
    Pete
    Here is the quick setup guide: https://www.powerbox-systems.com/upl...iGyro3e_en.pdf
    Appears to be just as simple as the Cortex. I need to stay out of this thread...starting to get buyer's remorse!
There are currently 35 users browsing this thread. (0 members and 35 guests)
