Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: CompARF Extra 330LX / DA200
    Received: 982
    This is CompARF’s newest Extra with all servos centered in middle of fuse -
    8 servos all positioned in fuse at wingtube!
    Peter got it painted in custom scheme!!!
    DA200L on MTW cans.
    Jeti / Mercury controlled
    JR HV servos
    Fully loaded!!
ID:	25424   Click image for larger version.
ID:	25425   Click image for larger version.
ID:	25426   Click image for larger version.
ID:	25427   Click image for larger version.
ID:	25429   Click image for larger version.
ID:	25430   Click image for larger version.
    Received: 982
    Re: CompARF Extra 330LX / DA200
    Main gear installed with gear cuffs!
    I like their new mounting system where the gear is clamped to the fuse - no weakening of the gear by drilling holes in it.
    The cuffs fit okay. Took lots of trimming. They don’t sit tight to the fuse so will add a bit of combing around them to finish it off better
ID:	25432   Click image for larger version.
ID:	25433   Click image for larger version.
ID:	25434   Click image for larger version.
    Received: 982
    White Rose tail wheel installed. Just waiting on some Mockingbird steering springs!
    Received: 113
    Given: 14
    Holy Crap ALL those servos are JUST for this plane?
    Where those pivoting horns in the fuse for Pull-Pull Rudder?
    That DA200 Looks Perrrrrty!
    Received: 982
    So on this new Extra, CARF molds in a firewall stub which is suited for a twin cylinder. And there is no 2.5deg offset angle. Up to the owner to add in offset and shorten if going with a longer motor like a quad.
    Hugely disappointing. Better ways of handling engine length. And at least put in the friggen offset. This will turn a lot of guys off for sure. Was eyeing one of these up for myself but not doing this again.
    Anyways, ignoring my rant, here are pictures of the shortening process / 2.5deg offset and new firewall.
ID:	25439   Click image for larger version.
ID:	25440   Click image for larger version.
ID:	25441   Click image for larger version.
ID:	25442   Click image for larger version.
    Received: 982
    Besides the Hysol holding the firewall, I laminated 6oz CF cloth / West System on the backside and added 12 button head screws as pins.
ID:	25445   Click image for larger version.
ID:	25446   Click image for larger version.
ID:	25447   Click image for larger version.
    Senior Member Buck Tracker's Avatar
    Dean
    Ponoka
    Received: 62
    Given: 153
    looks cool!
    Motor mount BS is just nuts
    Hey did his ailerons come with the mods or whatever they did to stop the flutter? I was reading some about it on FG
    Received: 982
    Quote Originally Posted by Buck Tracker View Post
    looks cool!
    Ya Dean... the ailerons each have a TE strip on them to stop the flutter!
    Received: 982
    Thank goodness for the posts on the main floor!!!
    Best way to mount the engines on these composite planes
ID:	25449   Click image for larger version.
    Received: 982
    DA200L mounted!!...
ID:	25451   Click image for larger version.
ID:	25452   Click image for larger version.
ID:	25453   Click image for larger version.
ID:	25454   Click image for larger version.
ID:	25456   Click image for larger version.
