This is a cool addition.. a tams nozzle in stainless steel!!!
And got the pipe installed.
Kingtech 160G2 installed!!
Main gear installed. Behotec C36 air
And here’s a quick picture of the servo leads and airlines organized and routed to the front
Tomorrow I will get the fuel tank mounted
Got the fuel tank in place.
The back is held down with a crossmember that ties into the turbine rails
The front is secured with a bracket at the top
Front fuse is attached!!!!!
Behotec C36 nose gear installed.
Savox 1267 for steering
| Received: 0 Given: 0 |
Hi Trevor Thank you for chosing the best accessories for this plane and keeping everything light !
Control horns glued into the rudders!!!
Mini servos are en route from Thunderboltrc![]()
Control horns glued into flaps and ailerons. Sooooo nice to have outboard flap linkages!
Will be using 4 x Savox1270’s in the wings with TBolt connectors
