Got the plates cut out of 1.5mm CF from Thunderbolt.
Working on the layout!!
Royal, CTU, fuel pump and smoke pump mounted to the fuse bottom.
| Received: 114 Given: 14 |
Royalty cheque is in the mail Jim!
Jeff at TBolt is now stocking those smaller Secraft metal arms. They are the real thing for narrow opening applications with clevis’.
The tubing is just 6mm Festo air line. Jim - You need to bring in more stock of that clear Eurathane tubing![]()
Here are a few pictures of the equipment trays all done!
Here are the setup specs I am using from Scott Marr....
CG: the
Back of wing tube up to 1”
Works out to 53mm in front of main gear axle for XiCoy machine
Required:
2 x GensAce 2S 3500mAH Lipos and a ThunderPower 2S 800 LiPo by nose gear
1 x 3S6000 LiFe beside main fuel tank
Throws:
Aileron: 12/20mm from tip. low/high
Flaps: Full 115mm from aileron. Mix 3-4mm down ele with full flap. Take off 25mm from aileron
Elevator: 10/13mm from tip. Low/high
Rudder: 75mm from base
Differential: None
And I made up a cradle for it and got it mounted in the trailer!!
As comparison I put the Rogue beside the T3.
Rogue is longer by a few inches
T3 is much taller
Rogue looks like a bullet. Can’t wait for a maiden soon!
| Received: 214 Given: 74 |
Man ohh man, that's some nice shiat
There are currently 2 users browsing this thread. (0 members and 2 guests)
