Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Elite Aerosports Rogue / KT320
    Wooohoo... received my new machine for 2021.
    Putting a KT320G2 in it. Futaba A700 servos. Powerbox Royal. Jeti telem and guidance
    I have a bunch of projects for others that I committed to already so this build will be here and there over the next couple of months
ID:	25145   Click image for larger version.
ID:	25146   Click image for larger version.
ID:	25147   Click image for larger version.
ID:	25148   Click image for larger version.
ID:	25150   Click image for larger version.
ID:	25151   Click image for larger version.
    Senior Member Daren71's Avatar
    Apr 2015
    Daren
    Mississauga, ON
    Received: 19
    Given: 179
    Re: Elite Aerosports Rogue / KT320
    Looks almost identical to an Eflite Habu 32x. Well, except the size, and the more zeros at the end of the price tag.
    https://www.horizonhobby.com/product...f/EFL8085.html
    LOL. Good point Darren.
    And sure is easier to transport!!!
    Received: 11
    Stop procrastinating and make some progress on this build, will ya 😛....nothing worse than starting a thread and not following through 😉🤪
    LOL. Frig - so much pressure now
    A700 mounted in rudder with a 1.25” metal arm. Nice short linkage.
    Thunderbolt locking connector
ID:	25154   Click image for larger version.
    Stabs done with a pair of A700’s. 1.25” metal arms.
    No surprises. Super easy install.
    I went with the Aeropanda MPX connectors on this one to try.
ID:	25156   Click image for larger version.
ID:	25157   Click image for larger version.
ID:	25158   Click image for larger version.
ID:	25159   Click image for larger version.
    Tail done!!!!
ID:	25161   Click image for larger version.
ID:	25162   Click image for larger version.
    Ailerons and flaps done on the Rogue wings.
    The servo arms for the ailerons are 1.5” - gives near 100% travel at full deflection
    The servo arms for the flaps are 21mm - I needed +115 / -118% for full deflection and arm is almost straight back at landing config for max leverage
ID:	25182   Click image for larger version.
ID:	25183   Click image for larger version.
    Electron landing gear! ER50!!
ID:	25190   Click image for larger version.
ID:	25191   Click image for larger version.
ID:	25192   Click image for larger version.
