Thread: Qty 3 MKS HV747 Digital High Torque High Voltage Servo, with Titanium Gears, Aluminum
    Received: 114
    Given: 14
    My Location: Mississauga ON L5N 1Z4
    New or Used: See Description Below
    Manufacture: MKS
    Asking Price: $295.00
    Qty 3 MKS HV747 Digital High Torque High Voltage Servo, with Titanium Gears, Aluminum Case c/w metal servo arm
    Lightly used in Electric airframe
    Features:
    12 x 20 mm coreless motor, High efficient, More durable
    9mm VR, Ultra high-resolution
    Unique gear structure with reduced backlash
    Specifications:
    Torque:
    • @6.0V: 163.8 oz-in (11.8 kg-cm)Â
    • @7.4V: 191.6 oz-in (13.8 kg-cm)
    • @8.2V: 208.3 oz-in (15 kg-cm)
    Speed:
    • @6.0V: 0.17 s
    • @7.4V: 0.14 s
    • @8.2V: 0.13 s
    • Weight: 38.55 g
    • Dimension: 35.5x15x28.5mm
    • Working Voltage: 5.5 ~ 8.4 V DC Volt
    • Working Frequency: 1520μs / 333hz
    • Dead Band: 0.001 ms (Default)
    • Bearing: Dual Ball Bearings
    • Motor: Coreless Motor
    • Gear: Chrome-Titanium alloy gear
    • Electric Current Drawï:2.6A max. (8.2V)”‚2.4A max. (7.4V)”‚2.0A max (6.0V)
    • Wire Length: 29.5 cm
    $295.00 Shipped!
ID:	24644   Click image for larger version.
ID:	24645   Click image for larger version.
