Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Eric Rís SkyMaster F14 - Loaded to the Hilt!!!
    Received: 980
    So Eric has officially lost his mind! Picked up this awesome F14! And Iím honored to put this together!!
    Itíll have all the bells and whistles possible. Will be a huge winter project. Heís been ordering stuff like crazy so time to get started.
    Huge congrats Eric. This is gonna be fun!!
ID:	24547   Click image for larger version.
    Received: 980
    Re: Eric Rís SkyMaster F14 - Loaded to the Hilt!!!
    So after doing 2 of these F14ís and probably 10 other Skymasters, my learning is if you want a reliable leak free air setup, every air cylinder needs to be serviced (internal orings), Festo tubing installed and all nipples sealed with Hysol. If you do this, itíll hold air for a long time. Skip this step and youíll be chasing slow leaks forever.
    Swingwing structure and main gear removed - now I can access all the gear door pistons for servicing and can fully tear down and rebuild gear.
ID:	24549   Click image for larger version.
ID:	24550   Click image for larger version.
ID:	24551   Click image for larger version.
    Received: 980
    These nipples are just screwed into the Skymaster cylinders with a course thread. 80% of them will have slow micro leaks. Add that up over 20 cylinders on a jet like this and Iíve seen pressure telemetry show 2-3 psi/minute air loss. Unacceptable. Threads need to be sealed
    Senior Member Bgelok's Avatar
    Brad Gelok
    Kingston, On
    Received: 44
    Given: 33
    Wow, that is gunna be whicked. Twin 120’s ?
    Gimmie the sticks, Iíll fly it !
    Received: 10
    Quote Originally Posted by Bgelok View Post
    Wow, that is gunna be whicked. Twin 120ís ?
    Not decided yet on the turbines....Leaning towards 160ís or possibly as high as 190ís....obviously over-kill but still looking at options 🙂
    Unlimited vertical, single engine performance, ordinance carrying, grass field performance....lots of factors
    Received: 980
    Ya ya! The only sensible option would be twin 190’s!!!!!!!
    Brad Gelok
    Kingston, On
    Received: 44
    Given: 33
    Quote Originally Posted by flyloose View Post
    Not decided yet on the turbines....Leaning towards 160’s or possibly as high as 190’s....obviously over-kill but still looking at options 
    sounds like you have to go with the 190’s then. Lol
    Received: 10
    sounds like you have to go with the 190ís then. Lol
    Well itís looking that way 🤪
    Received: 980
    So I have about a week’s worth of work now to pull ALL the air cylinders.
    Install Festo line
    Hysol nipples and airline
    Lube up cylinder internals/orings
ID:	24554   Click image for larger version.
ID:	24555   Click image for larger version.
    Senior Member DHC8's Avatar
    Louis
    Limoges
    Love your F-14 builds! I’ll be watching this one closely. Beautiful plane Eric, hope to see it next season!
    Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
