Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: Krill Ultimate V2 / GP123
  1. #31
    Received: 978
    Re: Krill Ultimate V2 / GP123
    Krill includes Ti axles and bearing-equipped wheels. Nothing is drilled or cutout or reinforced so wheels/pants/fairings took way longer than a normal ARF
    Exhaust extensions are from a Blade450 Helicopter boom so already anodized black.
ID:	24352   Click image for larger version.
ID:	24353   Click image for larger version.
ID:	24354   Click image for larger version.
  2. #32
    Senior Member Skier1960's Avatar
    Jun 2017
    Robert
    Alexandria Ont
    Received: 18
    Given: 50
    I notice the header has a square shape to fit the GP123. Where did you get the MTW headers. I used a round DA header with a square to round spacer on mine!
  3. #33
    Senior Member carrid02's Avatar
    Craig Rideout
    Abilene, Texas
    Futaba, because of Jim
    Received: 36
    Given: 27
    Here is the Mockingbird Aviation tail wheel springs installed. My favourite setup by far.
    Thanks Trev! Build is looking amazing! Now I want one of these geezus
  4. #34
    Received: 978
    Super excited to fly this Craig!!!
    Rob - those are MTW knuckle headers for GP from TBolt. The round ones that you have are DA120 headers with the Planebender adapters
  5. #35
    Received: 978
    Got all the horns Hysolíd into ailerons and elevators
    The kit comes with a drill template
ID:	24356   Click image for larger version.
ID:	24357   Click image for larger version.
ID:	24358   Click image for larger version.
  6. #36
    Received: 978
    Servos installed in top wing
    JR8955s.
    Arms are 2” SWB. Could have gotten away with 1.5” arms but only have 2”
ID:	24360   Click image for larger version.
ID:	24361   Click image for larger version.
  7. #37
    Received: 978
    JR8955’s in lower wings! Powerbox wire. Thunderboltrc connectors. Rubber grommets to protect the wire
ID:	24363   Click image for larger version.
ID:	24364   Click image for larger version.
ID:	24365   Click image for larger version.
ID:	24366   Click image for larger version.
  8. #38
    Received: 978
    Prop drilled and spinner cone cut to fit
ID:	24368   Click image for larger version.
  9. #39
    Received: 978
    Elevators finished.
    Again - could have went with 1.5Ē arms
ID:	24370   Click image for larger version.
ID:	24371   Click image for larger version.
  10. #40
    Received: 978
    All setup for the first time!!!
    Recommended CG is 180mm aft of upper wing LE point at center.
    Had to add 1.75lbs of lead to motorbox
    Nothing significant that I can move forward. That’s 2 Krills now that needed major nose weight - I think they are designed for heavy 3W’s. LOL
ID:	24373   Click image for larger version.
ID:	24374   Click image for larger version.
