Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Krill Ultimate V2 / GP123
  1. #21
    Received: 978
    Re: Krill Ultimate V2 / GP123
    The headers are MTW Knuckle Headers so I got the right shape/layout and then welded the knuckles with silver solder / MAP gas
  2. #22
    Senior Member hammonr's Avatar
    Rob H
    Ottawa
    Received: 44
    Given: 20
    Nice work Trev...looking good!
    Fly Hard and Don't Worry ...Only the Last Foot Hurts!
  3. #23
    Received: 978
    Talked to Peter and went with this design for exhaust outlets / canister cooling!
    With the canister offset the extensions will exit at front and back of the slots.
    Used the trusty Silouette to cut out a template for the dremel using masking vinyl
ID:	24325   Click image for larger version.
ID:	24326   Click image for larger version.
  4. #24
    Received: 978
    Got the fuel dot, ignition light and Powerbox switch installed.
    Made up plywood backing plates for each
    We’re going to try the new Powerbox Pioneer on this bird. So crazy small and the switch is way nicer than the big clunky black 3-button switch
ID:	24328   Click image for larger version.
ID:	24329   Click image for larger version.
ID:	24330   Click image for larger version.
  5. #25
    Received: 978
    Really nice tailwheel! Comes with the kit.
    I used 6-32 bolts and made up a tool to fish through blind nuts on the inside!!
ID:	24332   Click image for larger version.
  6. #26
    Received: 978
    Supplied control horns Hysolíd into Rudder.
    Iíll be using a set of Mockingbird tail wheel springs (thanks Craig!!) so cut out an oak block and inserted it into the rudder as a hard point for the tiller arm! The block ties into the control horn structure inside.
    Tomorrow I will blend this all in once the Hysol dries and will paint this area!
ID:	24334   Click image for larger version.
ID:	24335   Click image for larger version.
ID:	24336   Click image for larger version.
ID:	24337   Click image for larger version.
  7. #27
    Received: 978
    Tiller arm for tail wheel made from 2mm carbon fiber sheet.
ID:	24339   Click image for larger version.
ID:	24340   Click image for larger version.
  8. #28
    Received: 978
    Here is the Mockingbird Aviation tail wheel springs installed. My favourite setup by far.
ID:	24342   Click image for larger version.
ID:	24343   Click image for larger version.
ID:	24344   Click image for larger version.
  9. #29
    Received: 978
    Servos will be JR8955ís on aileron and elev. And a single JR8911 on rudd.
    Soft start is nice feature! And no potentiometer so perfectly quiet - no buzzing even under load. Kinda a little weird at first. I have used these in jets in the past and they are awesome. Eager to see how they work in a gasser
ID:	24346   Click image for larger version.
ID:	24347   Click image for larger version.
  10. #30
    Received: 978
    JR8911 installed for rudder. Secraft goodies on both ends!
    Double arm is a 3.5Ē with ball links at 3Ē
ID:	24349   Click image for larger version.
ID:	24350   Click image for larger version.
