Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Krill Ultimate V2 / GP123
    Received: 978
    Re: Krill Ultimate V2 / GP123
    So while the family was sleeping this AM, I got the fuse taped to a column on the main floor (high ceilings, LOL) and got the motor / standoff positioned on the motorbox!!
    Love this way of doing it! So precise!
ID:	24289   Click image for larger version.
ID:	24290   Click image for larger version.
ID:	24291   Click image for larger version.
ID:	24292   Click image for larger version.
    Received: 978
    And here’s the GP123 mounted!!
ID:	24294   Click image for larger version.
ID:	24295   Click image for larger version.
    Received: 978
    Ignition mounted. The exit holes in the mbox are lined with Velcro tape to prevent any chaffing/cutting of the ignition leads
ID:	24297   Click image for larger version.
ID:	24298   Click image for larger version.
    Received: 978
    So the good and bad is that Krill give you a shell with some formers... so had to make up a throttle servo tray. I wanted something where the servo was easily removeable and that the servo arm moved in same plane as throttle arm.
    After a bunch of cardboard templates, came up with this. Crazy sturdy inside the fuse. 0 flex.
    Love these little MKS servos!
    Throttle arm is a 15mm metal Secraft from Esprit Models... 2mm hole is drilled to 1/8” and the inner sleeve of Nyrod used as a bushing for the metal 4-40 clevis. Throttle rod is 4-40 threaded rod Hysol’d in CF tube.
ID:	24300   Click image for larger version.
ID:	24301   Click image for larger version.
ID:	24302   Click image for larger version.
ID:	24303   Click image for larger version.
ID:	24305   Click image for larger version.
ID:	24306   Click image for larger version.
    Received: 978
    Baffling done!!!! Used the 6mm foam from Michaels. Works awesome. Tacked with CA and then filleted with Clear Silicon
ID:	24308   Click image for larger version.
ID:	24309   Click image for larger version.
ID:	24310   Click image for larger version.
ID:	24311   Click image for larger version.
    Received: 978
    So not sure what Krill was thinking but they spaced the cans waaaaay too far apart on their mount. Can’t think of a single motor/can combo that this would work. Also I would need an 8” extension on the can stingers to exit the fuse because the cans are so high. Somebody was into the liquor at Krill !!
    First pic is the disaster
    Second pic is how the cans should be
    New can mount started this AM
ID:	24314   Click image for larger version.
ID:	24315   Click image for larger version.
    Received: 978
    Here is the new can mount.
    I moved the mount rearward also for 2 reasons...
    1) closer to CG of cans to take stress off the headers
    2) stronger because I could fillet Hysol onto the wingtube
ID:	24317   Click image for larger version.
    Received: 978
    Headerlength set at 11.5” with 1/8” gap at couplers to the MTW cans.
    Knuckle headers got Silver Soldered in the proper orientation.
ID:	24319   Click image for larger version.
    Received: 978
    And here’s the completed exhaust.
    The black sealant is “The Right Stuff”... a knockoff of Hondabond. Amazing sealant if you’ve never tried it. Only some Canadian Tires sell it.
ID:	24321   Click image for larger version.
ID:	24322   Click image for larger version.
ID:	24323   Click image for larger version.
    Peter Woo
    Thanks Trevor awesome job. Did you have to build the headers ?
