Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Servo extension wire?
    Senior Member DHC8's Avatar
    Louis
    Limoges
    Hey guys, I got a question regarding extension wire. From what I understand generally (depending the purpose of course) you want larger wires. I have pretty much always used the 20gauge wire from Tbolt, either pre-made or I make my own. I decided to try Powerbox Maxi wire on my last build. When I got it I was surprised that itís pretty thin gauge wire. The signal wire is pretty thin, but thatís fine, thereís no real amperage going through it. So itís good that itís thin, helps save weight. However the power wires are pretty thin as well, not sure of the gauge, but doesnít look more then 22, possibly smaller?
    So what your take on that? Would you/do you trust it in higher load systems. Iím thinking to re-wire my A10 with a Booma system and will need to instal new extensions. Whatchu guys think?
    Member Dansy's Avatar
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Given: 7
    Re: Servo extension wire?
    PowerBox wires is the best
    Daniel
    Louis
    Limoges
    Quote Originally Posted by Dansy View Post
    PowerBox wires is the best wire out there.....
    I didn’t ask if it was the best or not and Just because it’s “the best” doesn’t mean it’s is the best for the application.
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Given: 7
    Ahah....
    Sep 2015
    jason s
    futaba
    thunderboltrc has the new extreme wire which is pretty good I've just started using an happy with it..similar power box wire
    Received: 112
    Why?
    Can you qualify that statement?
    Dec 2016
    Daniel Dupont
    Prescott, Ont
    JETI DC-24
    Given: 7
    Quote Originally Posted by JDaly View Post
    Why?
    Yes, I could but he doesn’t want me to post on HIS tread.....so I won’t
    Nov 2015
    Angus McDonald
    Fernie
    Jeti DS-24
    Powerbox Forum site has some information on the cables just need to search it out, pretty sure the amp rating is greater than any powerbus rating in your power distribution box, sorry no specifics. they do rate the Maxi cable for 45kg servos ( wire length has a variable but not sure if that applies to most of our plane sizes)
    all I got, it is the best cable to work with, its all I use.
    Am
    Received: 976
    Absolutely no comparison.... nothing matches Powerbox wire! And the Powerbox ends are amazing to crimp.
    All you have to do is work with it and you’ll know
    And for jets, the current in the wires is next to nothing. I am also using PB wire on my 42% aerobat (big loads) and 0 issues! So cool that PB also went with a thinner signal wire! Smart thinking
    Just get a sample of each and try crimping ends... make your own judgement.
    Louis
    Limoges
    Thanks Trevor, yes for sure they are much easier to make extensions. I used PB wire in my marchetti build and it was nice to work with. Just wanted your opinion before I used it in my A-10!
