Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Stripped out prop hubs
    Orval Altwasser
    YellowGrass, Sasatchewan
    Spektrum , FlySky i10
    Received: 22
    Re: Stripped out prop hubs
    I think Joe, I’m just going to lathe out a new prop drill guide , make it so it pilots snugly into the original hub, clock it slightly , and redrill and tap 6 new 5 mm holes between the stripped holes and on a wider bolt circle than the original holes. I’ll send a picture of the old hub to better explain .
    Orval Altwasser
    Received: 22
    Black marker dots only an approximate location , but you get the idea.
    Received: 78
    Or you can tap it out to 6mm and buy 6mm bolts. I did that to one of my engines once, when the bolt holes stripped. Easy peasy.
    Orval Altwasser
    Received: 22
    Yup. That’s an option as well.
