Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Skymaster Large F18
  1. #11
    Senior Member tbrum's Avatar
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    Re: Skymaster Large F18
    MKS-599 servos on elevators.
    Exact same setup as the last two SM F14’s I’ve assembled so pretty familiar.
    Takes a bunch of shimming and adjusting but all good now!!
ID:	23467   Click image for larger version.
ID:	23468   Click image for larger version.
  2. #12
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    Rudders done also. MKS-599 servos again. I replaced the stock hardware with good Dubro HD ball ends and Ti links
  3. #13
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    If you’ve never used the Powerbox servo wire and connectors, you need to. About 1/2 the weight of normal wire and so easy to work with. Once you crimp these ends you will never go back.
    Found some clear HS tubing at Sayal.
ID:	23472   Click image for larger version.
  4. #14
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    Twin pipes and nozzles installed...
ID:	23474   Click image for larger version.
  5. #15
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    The pipes donít have much of a bell-mouth on them and the rudder servos are fairly close to the turbine nozzles so fabíd up some heat baffles. Feeling good about everything back there
ID:	23476   Click image for larger version.
ID:	23477   Click image for larger version.
ID:	23478   Click image for larger version.
ID:	23479   Click image for larger version.
  6. #16
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    1 Not allowed!
    Tomorrow Iíll work on installing the twin Cheetah 160ís!!!
  7. #17
    Senior Member
    Hanes E
    Received: 31
    Given: 40
    Quote Originally Posted by tbrum View Post
    What diameter of HS tubing did you grab. It is sweet looking
  8. #18
    Trevor B
    Today
    2.4ghz
    2 Post(s)
    Received: 974
    Given: 745
    Quote Originally Posted by Old School View Post
    3/8”
  9. #19
    Jan 2020
    Steven P
    Waterloo
    JR
    Hey,
    Where do you source the power box wire and connectors? What crimper is required? I make all my own extensions after having some issues with cheap ones.
    Thanks
    Steven
  10. #20
    Jan 2020
    Steven P
    Waterloo
    JR
    Hey,
    Thanks
    Steven
